Upshifting early
Old 03-31-16, 03:14 PM
RushNatU
RushNatU's Avatar
Default Upshifting early
I have owned two LS 430s now and they both do the same thing. If I hold my foot down on the gas pedal normally to accelerate like a grandpa, the transmission goes through first second, third, and once it hits fourth, then bogs down and shifts back down to third to accelerate. Normal behavour?
This is in ECT normal btw
Old 03-31-16, 04:31 PM
Tom57
Tom57's Avatar
Do a soft reset by disconnecting the battery for 5 - 10 minutes.
Old 03-31-16, 05:57 PM
RushNatU
RushNatU's Avatar
Thanks for your response! I am aware of the "learning" the ECU does and have tried the soft reset several times. If I push the gas a little more then it doesnt do this, only upon light acceleration both vehicles unshifted early.
Old 03-31-16, 06:22 PM
Tom57
Tom57's Avatar
What year?
Old 03-31-16, 11:24 PM
RushNatU
RushNatU's Avatar
01 and 02 LS
Old 04-01-16, 10:59 AM
KING
KING's Avatar
Stock air intake?
Old 04-02-16, 03:57 PM
airchomper
airchomper's Avatar
My '01 does this - it seems normal. It did this with the stock transmission fluid, it did this after a few drain and fills, it did this in the winter and the summer.
You can back off the gas pedal just a bit after it shifts to 4th and it'll stay in gear. Or you can accelerate just a bit harder, and the problem won't manifest.
For what it's worth - running 91 octane, ethanol free gas really reduces the frequency of this happening the car seems to be able to make more torque at lower RPMs with better gas.
14RX350
RX - 3rd Gen (2010-2015)
15
08-04-18 07:05 AM
462HO
04-11-18 01:12 PM
TBrathwait
08-31-17 07:19 AM
Amai21
11-08-13 05:43 AM
Stacyw
08-01-11 04:36 AM
Quick Reply: Upshifting early
