2003 LS 430 - AC Codes
Old 03-30-16, 07:56 PM
Arcturus
Arcturus's Avatar
Default 2003 LS 430 - AC Codes
Hello,
I checked my AC after the winter and it's not blowing cold air. I pulled the AC codes by holding the the "AUTO" and "RECIRCULATION" buttons on the dash and got the following error codes:
21
24
35
Can anyone tell me what they mean. I'm told 21 is for the solar sensor and since it was dark out I could understand why it would pop up.
For the other two I'm not sure. Can someone help me out?
Old 03-30-16, 09:14 PM
StanVanDam
StanVanDam's Avatar
B1421 (passenger side circuit) and B1424 (driver side circuit) is the front solar sensor, shining a bright light on it should clear these 2
B1435 is the Cool Air Bypass Damper Position Sensor Circuit (Passenger Side)
You can inspect the Cool Air Bypass Damper Control Servomotor by removing it and:
1) Applying battery voltage to terminal 5 and ground to terminal 4 should make the lever move smoothly to the SHUT position
2) Applying battery voltage to terminal 4 and ground to terminal 5 should make the lever move smoothly to the OPEN position.
Old 04-05-16, 07:54 PM
Arcturus
Arcturus's Avatar
Thanks very much. I tested the system again in daylight and 21 and 24 both went away. I'm only left with the 35 error code.
Do you have instructions on how to remove the Cool Air Bypass Damper Control Servomotor? Is this a big job?
Old 04-26-16, 04:15 PM
Arcturus
Arcturus's Avatar
Can anyone help me out with how to access the Cool Air Bypass Damper Control Servomotor to diagnose it? rkw?
Old 04-26-16, 05:38 PM
rkw77080
rkw77080's Avatar
Here you go, Arcturus!
Old 04-27-16, 05:56 AM
Arcturus
Arcturus's Avatar
Awesome thanks! Do you also have a copy of the manual detailing how I remove the servo motor (AC-78)?
Thanks again.
Old 04-27-16, 06:32 AM
rkw77080
rkw77080's Avatar
You're welcome. Here is the AC-78 page you requested...
File Type: pdf
Old 04-27-16, 12:00 PM
Arcturus
Arcturus's Avatar
Great. Any chance to get BO-128 and AC-44?
Old 04-27-16, 02:28 PM
rkw77080
rkw77080's Avatar
Per your request...
File Type: pdf
File Type: pdf
Old 04-27-16, 08:16 PM
Arcturus
Arcturus's Avatar
Per your request...
Perfect! You're a machine! Doesn't seem to bad to access it. Phew.
Last but not least would you have the pages:
DI-1867
DI-1851
With this I should be able to check it out. Thanks very much for your help.
Old 04-28-16, 03:28 AM
rkw77080
rkw77080's Avatar
Arcturus, you have DI-1851 already (see Post #5)... Here's DI-1867.
File Type: pdf
Old 04-29-16, 04:40 PM
Arcturus
Arcturus's Avatar
Didn't see that. Thanks. Think I have everything now. Appreciate the help.
Old 04-29-16, 07:29 PM
rkw77080
rkw77080's Avatar
You're welcome... have fun and let us know how things turn out for you.
netasp
07-01-19 05:50 AM
honeygee2
07-31-12 10:41 AM
Nosferatu2
08-22-09 09:34 AM
HoleinOne
09-24-02 01:54 AM
Quick Reply: 2003 LS 430 - AC Codes
