04 LS430 smart key problem
Old 04-02-13, 12:24 AM
Celsior21
Celsior21's Avatar
Default 04 LS430 smart key problem
Hey everyone..
Long story short, my battery took a dump yesterday. Got it charged and it's back in the car. Only problem now is that the smart key doesn't work anymore.
I cannot lock/unlock the car. Also I could only fire up the car with the key in the ignition. Without the key, it tells me " keys not detected, ". I have also double checked the battery on the remote as well as the smart key disable/enable function located on the bottom of the dash.
I tired searching but no luck.. Anybody can lmk thanks!!!
Old 04-02-13, 07:52 AM
choiceISF
choiceISF's Avatar
Under your steering wheel (if you haven't seen it before, stick you head under) there are two buttons.
1. for TPS reset
2. to acticate your smart key.
Try that.
Good Luck!
Old 04-02-13, 08:18 AM
Celsior21
Celsior21's Avatar
^^ I have already tried that. Thanks
Old 04-02-13, 08:46 AM
jayclapp
jayclapp's Avatar
Did you make sure that the cancel switch button is in the out position and not the pushed in position?
Old 04-02-13, 09:55 AM
Celsior21
Celsior21's Avatar
^^ yes. When the smart key button is in the disable position. The key light will not track in the car. Once it is enable the key light will flash, tracking the key.
Old 04-03-13, 03:55 PM
Celsior21
Celsior21's Avatar
Any other advice? Anybody know if there is any fuses that is associated to the smart key/smart access?
Old 04-06-13, 12:15 AM
lexusls4
lexusls4's Avatar
I ran into the same problem on my s500 . I believe you must have the key in the ignition and hold the lock button contiously until all door unlock . This is the initialze procedure that most factory used when a battery goes out on the key ,it also was the same for my e38 740 hope this help ..
Old 04-13-13, 12:24 AM
quixotic
quixotic's Avatar
on safecar.gov (NHTSA) there's an entry for the 2004 LS
Service Bulletin No.: 00304
Component(s): EQUIPMENT
NHTSA ID Number: 10008399
All Products Associated with this Service Bulletin
Vehicle MakeModelModel Year(s)
LEXUSLS 4302004
Details
0 Associated Documents
Manufacturer: TOYOTA MOTOR CORPORATION
SUMMARY:
REPAIR MANUAL SUPPLEMENT:SMART KEY REGISTRATION. *MJ
Not sure if it would be helpful or not since I can't actually see the TSB. Maybe your dealer could tell you.
Old 04-25-14, 01:49 PM
chris81964
chris81964's Avatar
Default Thank you
1. for TPS reset
Try that.
Good Luck!
It fixed mine. Thank you so much
mikevanle
11-29-23 07:24 PM
chrizzyyp
02-19-16 12:04 AM
aristoboyy
02-08-16 10:35 PM
marksm
RX - 1st Gen (1999-2003)
08-17-15 03:13 PM
ZAM
RC - 1st Gen (2015-present)
20
07-10-15 09:18 PM
Quick Reply: 04 LS430 smart key problem
