96 LS 400 Security system/starting problem
Old 11-23-16, 12:34 PM
Lykos1uzfe
Lykos1uzfe's Avatar
Default 96 LS 400 Security system/starting problem
I washed my engine and that's when starting problem first happened. Starter just clicks as I turn the key. It has been doing this for a while now every time it reigns. I haven't been using my original keyless remote ever since the first time it wouldn't start. So I guess my question is how to replace the module for security system because I don't want to disable it? Sometimes (very seldom) the car would only lock, nothing else, battery in remote is good.
I would like to keep it as original as possible.
It has no aftermarket security system or remote start.
Where exactly is the security system located (or its main components)? Is there a fuse or reley I should check?
Old 11-23-16, 07:57 PM
dicer
dicer's Avatar
If the starter makes a click noise the problem is not the security system. It could be bad, dirty, corroded, messed up, battery terminal connections, also the ground connection. The rain and moisture is helping to aggravate the condition. That's my guess.
Old 11-23-16, 08:16 PM
Lykos1uzfe
Lykos1uzfe's Avatar
Default Starter replaced at 120,000mi
Starter was replaced with OEM starter at 125,000mi
the car now has 197000mi
Checked all the possibilities of bad connections and also inspected every single fuse.
Next time it does it I will record a video. If I can catch it.
The click doesn't seem to come from starter. Somewhere behind the ignition column or maby behind the dash.
Only when it reigns very bad or as soon as I sprey motor a little bit.
Other than that not a single oil leek, previous owner gave me everything he had far as maintenence goes, he owned it from 60000 to 166000 miles.
100% Lexus maintained.
I apriciate your advice and I will check all the connections and battery terminals again.
Old 11-23-16, 08:47 PM
RA40
Super Moderator
RA40's Avatar
As dicer mentions about washing the engine and rain, water in the connectors will have adverse issues to deal with. How long ago did you wash the engine? What is the battery voltage?
Old 11-23-16, 08:52 PM
Lykos1uzfe
Lykos1uzfe's Avatar
1.5 years ago engine was washed. Battery 3 years old with Lexus 8 yr warranty, battery voltage I still have to check but it fires right up and interior/exterior lights are strong and bright all the time. That's the only thing, when it reigns or gets wet.
The only other thing I can think of is pull it in to the shop and start sprinkling the motor... LOL
Old 11-23-16, 08:53 PM
Lykos1uzfe
Lykos1uzfe's Avatar
All this started when engine was washed, that's when factory keyless entry stopped working also...
Old 11-24-16, 09:31 AM
dicer
dicer's Avatar
Reigns -----------> To hold a royal office, like a king or queen. So your saying the car becomes a king or queen some days and doesn't run?
Or do you mean when it RAINS?
And sorry mechanics, machinists, electronics, and programmers, have to get things exact. Since I do all them I get a bit picky.
SPRAY motor.........
Old 11-24-16, 05:45 PM
Yamae
Yamae's Avatar
"To err is human, to forgive divine", dicer.
Regarding the problem, I'd monitor the voltage at the terminal 5-2H of the J/B No.2.
Below is the related wiring diagram of a Celsior but a USDM should be the same.
Attached Thumbnails 96 LS 400 Security system/starting problem-starter-circuit.png
Old 11-24-16, 08:10 PM
dicer
dicer's Avatar
Just being a bit more accurate I goof up spelling or hit the wrong key or miss something too when writing. Its just a pet peeve I guess.
Raidin
CT 200h Model (2011-2017)
09-14-16 12:12 AM
tc_emcee
11-17-10 10:52 PM
Gunnut
10-06-08 02:12 PM
agc
07-12-05 10:16 AM
c_hatter
06-21-01 11:46 AM
Quick Reply: 96 LS 400 Security system/starting problem
