HOw much would you offer?
Old 01-07-16, 03:59 PM
chuck1022
chuck1022's Avatar
Default HOw much would you offer?
http://phoenix.craigslist.org/wvl/cto/5392686111.html.
Old 01-07-16, 04:16 PM
9000revs
9000revs's Avatar
Pretty good price already it seems, try for 5K maybe.
Old 01-07-16, 04:36 PM
aptoslexus
aptoslexus's Avatar
That's a reasonable price. I'm guessing it needs a timing belt, so I would use that to knock it down as close to $5 grand as I could.
Old 01-07-16, 06:12 PM
CELSI0R
CELSI0R's Avatar
I would offer $4.5k, since it may need a belt as aptoslexus mentioned, and it may need some other repairs.
Then, I would try to get the owner to meet in the middle.
Old 01-07-16, 06:46 PM
chuck1022
chuck1022's Avatar
im not the kind of person that is going to try and buy it for $1000 and take advantage if someone. I am willing to be fair, but im tryibg to figure out "fair"
timing belt......
all that
Old 01-07-16, 08:04 PM
CELSI0R
CELSI0R's Avatar
timing belt......
all that
Nor am I, chuck; however, I would like to get it for a good price, considering repairs that may be necessary. As I said, I'm assuming it needs a new belt and some mechanical repairs.
$5200, which is between $4.5k and $5.9k is a very fair price, with repairs needed...
[A timing belt change costs around $600 as-is]
Old 01-08-16, 02:35 AM
dicer
dicer's Avatar
As long as it has zero damage and repaint. The price is not too bad. How bad do you want it?
Try to get some off for need of timing belt stuff, if the timing belt was done and it has a good service history, you are getting a decent car for the price. Here a dealer would ask 10k plus for it. Always hit them with a lower price don't wait too long.
Make sure everything works. If AC does not work that's a huge deal, almost on the order of a bad transmission depending on the problem.
Check the engine oil make sure it looks clean, coolant, transmission fluid etc. good tires? any front end noise and looseness, drive a bumpy back road.
All lights okay? Any lights in the cluster on or out? Make sure the correct transmission fluid was used if it was changed.
Any problems need to detract from the price.
Old 01-08-16, 04:54 AM
pmarr
pmarr's Avatar
http://phoenix.craigslist.org/nph/cto/5359673604.html
Did someone miss this knucklehead?
Old 01-08-16, 01:17 PM
SteezyLS98
SteezyLS98's Avatar
5grand thats how mine was when i bought it but he had everything checked since he worked at lexus dealership gl tho
r4614
06-11-20 03:45 AM
Oomfh
12-19-18 06:18 PM
BobDigital
GX - 1st Gen (2004-2009)
24
06-20-18 08:25 AM
GrantM
07-14-11 07:53 AM
greenpea
Performance & Maintenance
03-29-09 11:14 AM
Quick Reply: HOw much would you offer?
