stock 2000 LS 400 toe alignment specs?
Old 01-28-14, 09:03 PM
Greg5OH
Greg5OH's Avatar
Default stock 2000 LS 400 toe alignment specs?
What is the factory recommended setting for toe setting front and rear? In mm or inch. no degrees plz.
From waht ive been reading, 0.5-1mm toe in front, 2mmish toe in rear. ?
Old 01-29-14, 06:22 AM
Greg5OH
Greg5OH's Avatar
nobody knows?
Old 01-29-14, 11:40 AM
timmy0tool
timmy0tool's Avatar
front toe should always be set to 0.
rear toe is a toe-in but i don't know the actual specs.
Old 01-29-14, 12:08 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
actually the LS never had a factory to spec of "0". Generally most cars (not sports cars) have some toe-in in the front for better stability/on-center feel.
factory spec is 0°12’ ± 12’ (0.2° ± 0.2°) in the front, A + B: 0°18’ ± 12’ (0.3° ± 0.2°) for the rear. Specs are for a '98-00 coil spring car.
Old 01-29-14, 07:58 PM
Greg5OH
Greg5OH's Avatar
I ended up setting both front and rear to 1mm toe in.
Will test and ride tomorrow
I like my foxbody with 0 toe in, makes for a snappy steering response.
Old 01-29-14, 08:41 PM
Yamae
Yamae's Avatar
I found this in the JDM manual. There are some differences between the spring and the air models especially at the rear camber.
Attached Thumbnails stock 2000 LS 400 toe alignment specs?-ucf20-21-allignment-spec.jpg
Snowrydr01
07-07-15 12:17 PM
nandob
Suspension and Brakes
02-21-14 05:29 PM
na4now
09-17-07 09:45 PM
Lexs400
12-13-04 03:18 PM
Quick Reply: stock 2000 LS 400 toe alignment specs?
