Supra TT Springs Vs LS400
Has anyone tried Supra TT Springs on LS400? I have a set in my parts closet.
Fronts should fit, but not sure about the rears.
For SC300/SC400 it provides a nice subtle drop for a cheap price.
JZA80 OEM Spring Rate:
430 lb/in Front
219 lb/in Rear
Tanabe Lowering Spring Rate (Gen1 or Gen2):
352 lb/in Front
168 lb/in Rear
430 lb/in Front
219 lb/in Rear
352 lb/in Front
168 lb/in Rear
Super Moderator
PD answered for the MkIV:
https://www.clublexus.com/forums/ls4...rk-on-ls4.html
MKIII discussion:
https://www.clublexus.com/forums/ls4...-on-ucf20.html
MKIII discussion:
So it's settled;
Get some new shocks and mount the springs on. Test with lots of photos while installing and post here we'll know.
Think this is an excellent excuse to seclude yourself from wife/girlfriend/significantother for a day.
The fronts should be no problem. They fit on SC, GS, Even MK3 Supra. You can see looking at the pictures that they look nearly the same just shorter (but thicker).
The rears are another story. I have to get 95+ rear shocks and hope that the springs won't be so short that it causes a saggy rear lol. If the rear is too short I can add a spacer to the top.
Ive seen a couple of complaints that Tanabes were too soft, so this might be a better option if we can get it right. Plus Supra TT Springs go for about $50 a set, so the price is right.
BahHumBug
you realize the LS is very different from ALL the models you just listed, right?
The SC, GS, and mk3 were all made to fit JZ series engines so have somewhat similar base architectures. The LS was designed from the ground up to be totally different and hence it has VERY few interchangeable parts with these cars.
Then there's the weight aspect to consider, that fat iron block JZ motor is going to require much stiffer stock springs in the front vs. the back compared to a 1/3 UZ engine'd car.
