Is it my alternator?
Old 04-21-13, 07:07 PM
LS400BOY
LS400BOY's Avatar
Default Is it my alternator?
hello all,i got a 92 ls400 and battery died and had to get a jump, i thought i left the lights on or my car audio drained it out? so i recharged the battery for a day,worked good for 2 days now its dead again, i had replaced my alt last year due to leaking power steering pump and its a pain to do so i was wondering if theres a alt fuse some where or and trick i can do to make sure its my alternator before i pull it out??? thanks much
Old 04-21-13, 07:15 PM
LScowboyLS
LScowboyLS's Avatar
it could be several things:
1. battery terminals (positive especially likes to develop hidden corrosion under bolt where cable attaches, replace with real dealership part from any Toyota dealer)
2. alternator
3. Your battery is itself is going bad
4. bad engine ground(s)
5. Fuse or Fuse link
you did fix the PS leak, right?
Old 04-21-13, 07:19 PM
LS400BOY
LS400BOY's Avatar
yes the leak is fixed,the battery cables had very little corosion so i doubt that,where is the fuse/fuse link??
Old 04-21-13, 07:44 PM
YoshiMan
YoshiMan's Avatar
How old is the battery?
If the cars starts and drives fine on its own, it's unlikely that the alternator is at fault.
Old 04-21-13, 07:54 PM
LS400BOY
LS400BOY's Avatar
Well since i owned the car 3 years,never replaced it and dont know how long the previouse owner had that battery in there?? If i remember right if it is the alternater when driving it would kill the battery and the car would just cut off since the alt not feeding the battery correct? Even worse at night since lights are being used
Old 04-21-13, 08:07 PM
HoodFellas
HoodFellas's Avatar
this is what you do to check the alternator working condition. put the battery on charge for like an hour or two. put the battery in the car and start it. now once the car is running take the battery out. if the car is still running, the alternator is good. if it shuts down than its a bad alternator. the battery light should also come on the dashboard indicating its not getting any charge. you could possibly have a short circuit. i had a similar problem where my amplifier was bad and it caused the battery to drain. took the fuse out and temperory fix until i replaced my amp. good luck.
Old 04-21-13, 08:28 PM
LS400BOY
LS400BOY's Avatar
So just basically unhook the cables and that should pretty much tell me whats wrong
Old 04-21-13, 09:15 PM
HoodFellas
HoodFellas's Avatar
yes. but i doubt its the alternator since you said you drove it 2 days after jump starting it. you would only last about 30-45 mins if the battery is fully charged and alternator is bad. all the lights on the dashboard would come on and the lights will dim and car will shut down. what im thinking is a bad weak battery not able to hold charge or u have a short somewhere, letting out the charge
Old 04-21-13, 09:23 PM
LS400BOY
LS400BOY's Avatar
i hope its just the battery being old,im going to do this test tomarrow and hope the alt good and it just is the battery, i still want to check the alt fuse/fuse link still where is this under the hood fuse?
Old 04-21-13, 10:24 PM
PureDrifter
BahHumBug
Forum Moderator
PureDrifter's Avatar
sounds like a dead battery...
Old 04-22-13, 07:55 AM
LS400BOY
LS400BOY's Avatar
I HOPE SO
Old 04-22-13, 11:22 AM
PureDrifter
BahHumBug
Forum Moderator
I DO TOO.
please stop yelling.
Old 04-22-13, 01:12 PM
LS400BOY
LS400BOY's Avatar
Well i just bought the battery,i 4got to do the test with taking off the cables because the wife had to take the car to work,o well guess ill find out sooner or later lol
Old 04-22-13, 09:18 PM
LScowboyLS
LScowboyLS's Avatar
batteries 4 years or older are VERY SUSPECT and can fail at any time.
Old 04-23-13, 10:51 AM
YoshiMan
YoshiMan's Avatar
DON'T DO THIS. It is a TERRIBLE idea to disconnect the battery with the engine running!! You can fry all sorts of very expensive electronics, especially on a power option laden car like the LS400.
Quick Reply: Is it my alternator?
