Low temperature reading gauge
Old 04-09-12, 07:50 PM
dr gtr
dr gtr's Avatar
Default Low temperature reading gauge
For months my one would move only to the first line. Just above "c"
I tried 3 different temp senders.
At the time i believe it was the temp sender because when I grounded the plug the needle went all the way up.
So receiving my 3rd sender and putting it in and doing the same. I had an Apithany.
Sticky needle like the rest?
so what I did was grounded the plug over 20 times as in on and off.
Worked for me. Must of loosen up the needle. Now just sitting below half where it should be.
Hope this helps.
So happy.
Old 04-09-12, 08:09 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
hmm makes some level of sense... hope it doesnt damage the gauge motor though.
Old 04-09-12, 09:17 PM
AYEmike
AYEmike's Avatar
mine sits right at the line that's under the invisible middle line, its been there forever. might consider changing the thermostat, sounds good? other members here has their temp needle sitting right a little above the line thats under the middle of the gauge
Old 04-09-12, 09:40 PM
dr gtr
dr gtr's Avatar
When I first tried it. I only did it I only earthed it about 6 times.
Plugged it in and it was only 1/4 of the way.
Then I thought well go all out. After 20 times. Must of loosened the needle.
Worked.
This worked for me. Honestly I am happy as.
Maybe the needle gets sticky over time? Some start to get lower and lower.
Hopefully this will help others too. Hopefully someone can try if they are having similary symptoms.
Old 06-05-12, 11:17 AM
JOEYD2008
JOEYD2008's Avatar
Hope this helps.
So happy.
How do you ground it? I am experiencing the same issue.
Thanks for your help.
jewelerz
30
01-21-18 09:20 AM
satiger
12
11-06-16 08:46 AM
BigD
17
12-03-15 02:19 PM
Rasimmo
12
05-07-13 07:54 PM
Supra Dr
Performance & Maintenance
12
07-07-11 12:33 AM
Quick Reply: Low temperature reading gauge
