Help!! Steering wheel problems!!
Old 05-14-11, 03:02 PM
DefendHI
DefendHI's Avatar
Default Help!! Steering wheel problems!!
I have 2000 ls400..i just change the battery on it.. Now everything works fine but the telescoping steering wheel wont move when i put the key in the ignition..it was working fine before i change the battery..it moves in and out but doesnt drop down automatic into place when i put the key in the ignition....
Please help!!!
Old 05-14-11, 06:13 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
check ALL fuses...
Old 05-14-11, 06:16 PM
bthomas
bthomas's Avatar
Does it go up when key removed?
Old 05-14-11, 07:32 PM
DefendHI
DefendHI's Avatar
Originally Posted by PureDrifter
check ALL fuses...
yeah i check all the fuse under the hood..is there another fuse box some where?
Old 05-14-11, 07:34 PM
DefendHI
DefendHI's Avatar
no it does not..if you adjust it from the toggle switch..it only moves in and out but not up and down..
Old 05-17-11, 11:38 AM
DefendHI
DefendHI's Avatar
Anymore suggestions?
Old 09-06-11, 06:18 PM
dsolomon
dsolomon's Avatar
DefendHI,
Did you have any luck solving this issue? Just had the same thing happen on my 99.
Thanks, Dan
Old 02-08-12, 10:56 AM
Cblair
Cblair's Avatar
I'm new to this and I'm trying to figure my steering wheel problem out too, but there is a fuse box way under the driver side door too, you have to look under the wheel, it's probably close to the parking brake
Old 02-09-12, 05:08 AM
billydpowe
billydpowe's Avatar
A few months back, I had a new tilt motor replaced in my 99. and last week I took the old one apart, I could not turn it. after disassembly, I was surprised how simple it is inside. my shaft was stuck in the bearing, I pulled the shield off and lubed it and it freed up and was easier to turn. there were no broken or loose parts. and probably a new bearing would have saved a lot of money. I did not try to remove the bearing, probably should have to see if I could match it up. any way if you are handy with your hands/tools, you might want to try fixing yours.
Old 02-09-12, 07:47 AM
fixmiester
fixmiester's Avatar
Default Steering wheel movement failure
Billy, I think I saw a previous post that you hadn't plugged the motor in yet to verify that it worked. Did that do the job?
Also, I have seen several posts on this subject that seem to correspond to folks that have just changed out their battery. In fact, that is when I first discovered my exact same symptoms a few years ago, as well. At the time, I thought it was just a coincidence, and I wasn't aware of the Lexus forums. Now I'm suspecting otherwise. It may have something to do with a worn-out or struggling motor, that finally jambs up hard when given a better power source. OR, could it be something in the control circuit that is tripping out, because of the higher battery voltage, resulting in higher current draw? Root cause analysis always makes perfect sense, in hindsight, but the correlation here seems a little too coincidental. Anyone know of a possible link, or solution?
Steve
Old 02-09-12, 08:38 AM
billydpowe
billydpowe's Avatar
Steve,
NO I have not plugged it in, my point above is that I could NOT turn it before disassembly and could turn by hand after lubing the bearing. I do not know if it would work properly now.
Old 03-05-12, 09:35 PM
Live4brew
Live4brew's Avatar
Now that I think about it...
I had a similar issue when my power steering pump leak ruined my alternator and battery. After I replaced those three, my steering wheel would move some but would grind as if gears were stripping (they were). Not sure why they were related, but I made a shim and installed it under the gearing to the left of the steering column (do a search, don't have a link bookmarked). Now it works fine, but (as has been for the 8 years I've had the car) it's just noisy. My buddies' 99 is silent. Not sure what is causing the whine.
Old 03-06-12, 03:57 PM
firefinder
firefinder's Avatar
try pressing toggle downwards 10 times ..hope it helps..
Jeremiah87
09-01-23 02:09 PM
peenlrd
03-27-18 07:09 PM
hms09
06-23-13 01:54 PM
dnguyen_GS430
08-27-10 11:04 AM
Quick Reply: Help!! Steering wheel problems!!
