Thumping noise coming from front suspension
Old 04-22-09, 12:51 PM
Jasoneo5
Jasoneo5's Avatar
Default Thumping noise coming from front suspension
Hey all,
A few weeks ago I hit a nasty bump in the road. Ever since I've had a thumping noise coming from the front driver-side. The rim was a tad bit bent so I went ahead and replaced it and put on a new tire. Still, the thumping noise is there. You can physically feel and hear it above speeds of 40, mostly when you are turning or veering right on the freeway, putting the weight transfer on that side of the car.
Any Ideas on what this might be? Is there a joint that I messed up? If so where is it/what is it called?
Thanks!
-Jason
Old 04-22-09, 01:16 PM
soutmezgui
soutmezgui's Avatar
Id's say control arm, I have a similer problem with mine feels funny when making turns and sometimes i hear/feel grinding comming from there when turning into parking spaces.
Old 04-22-09, 02:15 PM
Jasoneo5
Jasoneo5's Avatar
As in the control arm bushings? How much am I looking at you think? Any side effects other than abnormal tire wear?
Old 04-22-09, 02:21 PM
soutmezgui
soutmezgui's Avatar
Well mine is the control arm and my shop said they could get me a used one for like 200.00 then the labor to put it on if I don't do it myself. Most shops will give a free estimate so get them to check it for you before you just order the part. It might be the bushings I'm not sure just giving some advice based on my experiance.
Old 04-22-09, 07:27 PM
JimsGX
JimsGX's Avatar
You can buy a complete set of two front arms for $199.00 here at this link below. New bushings and upper ball joints included:
http://www.arnottindustries.com/part...65_gid422.html
Old 04-22-09, 07:54 PM
Jasoneo5
Jasoneo5's Avatar
Darn. Too bad I've got a 99
Old 04-22-09, 09:28 PM
ucfjon
ucfjon's Avatar
have you tried looking?
Old 04-23-09, 07:40 PM
soutmezgui
soutmezgui's Avatar
Sweet thanks that will be the next part I order.
Old 04-23-09, 07:46 PM
Jasoneo5
Jasoneo5's Avatar
Yeah, all I could find was one website that sells them for about 250 EACH. Sucks I know, anybody else know of anything.....Has Daizen come out with one for 95-00 LS yet?
Old 04-23-09, 10:41 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
that's actually pretty cheap, the OEM arms are normally about $350ish each new.
Old 04-27-09, 01:41 AM
vicpai
vicpai's Avatar
Lightbulb Actually....
.....I just checked their website and they have the UCAs for the 1995-2000 as well!!!!. I have a 2000 and have been dealing with a bad ride problem for a couple years now, right after the front AIR SHOCKS were replaced for a cool $2000!!!! ......anyways after lots and lots and lots of going back to the dealer (they even replaced the shocks once again!!) - dealership never resolved the problem-, and doing tons of research on my own on this, it appears that the shocks/air susp.system may not be to blame after all!! I think it may be worn out bushings!!
I just purchased a 2005 Acura MDX with approx. 37K miles on it and it exhibits a similar pattern. Sometimes the ride is SUPER SMOOTH and other times it's a bit FIRM AND HARSH......and the MDX does not have an "ACTIVE" suspension!!! However, because the problem was INTERMITTENT (on the Lexus and Acura) I could not see how bushings could affect this.
Then on further investigation I read somewhere (on the MDX forums) that depending on temperature and humidity, the old "worn out and aged" rubber could become MORE or LESS "compliant" and a poster there had success changing the swaybar bushings. This seems to make sense. So, I'm hoping changing the control arms will solve the problem.
Can someone tell me if the LOWER CONTROL ARM BUSHINGS should be changed as well?? How about the swaybar??
Thanks!
RXGS
Suspension and Brakes
18
10-27-13 08:30 PM
anesthesia
02-05-13 03:16 PM
ALLWiTE2JZ
11-06-09 11:06 PM
Brandicus
11-09-07 02:25 PM
aasc300
09-09-03 05:56 AM
Quick Reply: Thumping noise coming from front suspension
