Trasmission filter, 4 magnetic pieces.
95 LS 173,000
Just changed the transmission filter and fluid. it was black as black. Inside the pan there 4 magnetic pieces. After I had done everything and everything was back together I noticed I had forgatten to put this 4 pieces back in the pan. What are the 4 magnetic pieces for and will the car have any prblems becuase they are not there.
Super Moderator
95 LS 173,000
You really want them there as they keep the bits from going back in the tranny. Only once in my RX did I have an issue with some really silvery/pinkish flush that had bits in it. When I have ben draining my tranny I don't notice any bits in the fluid.
As far as if you want to put the magnets back in the tranny now, it depends when you are going to do your next change out.
I just did the trans fluid so, How long can I live without them. I talked to a few mechanis and they sasi the same thing you said. However, they told me the car should be fine and I should not wotty about. Then again, I am a firm believer that if it was there when you took it out, then put it back. Question, how often does the trans fluid needs to be change. and can I wait until the next change to pit the pieces back. Thanks.
Super Moderator
Still Leaking Trans fluid
I dont understand this car. I drained about a quart from the pan. Than I added a little bit while the car was running as requested. I had a mechanic check it after I drove the car in the highway and with the car running the dipstick was below the hot mark and just a little above the cold mark. he recommended me to add more fluid. I explained to him that it was leaking and I just drained about a quart. I took his advised and added another quart while the car was running, When we checked it again, the dipstick came to the hot mark, he said it was good now. However, I drove the car again and is still leaking like crazy. I dont know what to do.
Note: I may have tightened the pan gasket too much. the mechanic said it should not be too tight, becuase you may actually break the gasket. With that said, a troubling issue is the hot and cold indication of the fluid. Any assistance will be appreciated. Thanks
Super Moderator
Locating any and all leaks is key. I had a leak on mine and it turns out I didn't tighten the drain plug tight enough. The mechanic is right in your second paragraph. That gasket can get worn down over time (thinner) after tightening it and needs to be replaced. Sometimes it is a rubber material, sometimes a cork like material. Again, what you do next requires you to locate where the leak is...on the gasket, on the back of the tranny along the seal (a common place).
did you replace the gasket material? the gasket on the pan is not cork or rubber, they use the fipg (formed in place gasket) stuff. i'm not sure if it's similar to the silicone gasket (like caulking) material they sell at part stores. if you break that seal, you are supposed to clean both mating surfaces and reapply to the entire seating surface. it's the same goop used when replacing the water pump.
95 LS 174,000
No, I did not. I simply used the rubber gasket that came with the filter. It actually shows in the tutorial LEXLS how to do it and it shows the rubber gasket being replace. I was on another forum and it says the same thing you said about resealing it with that stuff after you break the seal, which it was a real pain to break. Its probably leaking from that same gasket that was replace. Do you, or anybody knows what that seal is exactly, or something similar. I would hate to have problems with the transmission over something so simple.
The LexLS.com tutorials have great stuff as far as doing you own maintanance. However, I've noticed there little things like this that are missing and if you are not careful, you can end up spending a whole lot of $$$$ because you are trying to save a few bucks. Furthermore, there is alot of stuff in there that only pertains to 90-94 LS.
alchemist
01-09-14 05:29 PM
