Ball joints replaced
Old 05-17-07, 08:15 PM
maxgee
maxgee's Avatar
Default Ball joints replaced
Changed the ball joints on my 95 LS. I had a noise that sounded like it was coming thru the floor and was advised by members on here to replace the balljoints. Well I did and all is fine...no more noise...smooth over bumps.
Thanks guys.
Old 05-17-07, 08:25 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
glad to see you got it resolved
u replaced upper, lower or both?
Old 05-18-07, 07:15 AM
maxgee
maxgee's Avatar
The lowers.
Old 05-18-07, 10:59 AM
steveski
steveski's Avatar
Max - I had pretty terrible inner tire wear when my lowers were bad. Pretty embarassed that I never noticed it ahead of time! Since I replaced the lowers and my front tires last November everything is fixed - no clunks and no abnormal tire wear. Did you see and tire wear bro?
Also I still have OEM upper CA's after 179,000 miles Alignment and wear patterns are all normal - no vibration, thumps, etc.
Old 05-18-07, 04:29 PM
maxgee
maxgee's Avatar
I can't say I noticed abnormal wear on the tires. The problem I was having is a lot of noise when going over imperfections in the road.
I plan on replacing the control arms and struts end of summer.
Old 05-19-07, 11:17 AM
steveski
steveski's Avatar
Interesting. I was getting the thump going over bumps - turned out to NOT be the strut bar but the lowers. My right side lower was the worst.
I would like to change my uppers as well - I will do it myself as it is not hard. Too bad Daizen doesn't make upgraded uppers. I bet they are stiffer and provide a better ride than OEM.
Old 05-20-07, 10:22 PM
Broker404
Broker404's Avatar
Do they make lowers for a 99? I have clunking and some suspension noises, esp from the front right of the car, and I'm not exactly sure if it's the ball joints, sway bar bushings, control arm bushings, or what. Either way, I'd like to go with aftermarket upgraded parts if there is something better than OEM available without any disadvantages.
Old 05-20-07, 11:16 PM
PureDrifter
BahHumBug
stiff balljoints = stiff ride, esp. if u put poly into the control arms too.
Old 05-22-07, 12:56 PM
steveski
steveski's Avatar
I hear you bro I do not believe the Daizen's are out. Too bad as there are plenty of folks here that would ****** them up. Pure is right, there are upgraded CA bushings available that will really make a difference. I am thinking that will my next upgrade as it only requires (4) bushings. My only problem is high mileage and I would be better off with a full OEM replace ment to get the new upper ball joint (with OEM bushings). If you find any ideas on upgrades bro let us know - 95 to 00 shuld be universal.
cm0nkey
Suspension and Brakes
136
09-04-18 09:04 PM
lextout
12
07-19-16 01:01 PM
lhgdale
10-27-14 09:23 PM
Max Power
09-03-10 05:26 PM
GQD_GS4
02-27-06 06:55 PM
Quick Reply: Ball joints replaced
