Speedometer MPH and horn
Old 03-18-05, 09:01 PM
YSITIS
YSITIS's Avatar
Default Speedometer MPH and horn
Just purchased a 1991 LS 400. Horn doesn't work and the speedometer MPH won't budge. The whole cluster works fine and the speedo lights up, just won't accelerate. Its so dead its below the "0". This is a brand new platform for me, so any help would be greatly appreciated. I would check the fuse for the horn if I new where the fuse box was. Plus, are there any manuals out there like a Haynes for the low level mechanic like me?
Old 03-22-05, 07:55 AM
leosls400
leosls400's Avatar
Welcome to Club Lexus,
Ive heard of bad clusters but yours seems to be something different as yours does light up and only speedo is not working. Check other threads under "cluster repair" and you will find many talking of the problems they encountered with the clusters. As for repair manuals, you have to get one specifically to your year from the toyota and down load from website at http://techinfo.lexus.com/. I believe it cost $10 dollars to get a manual that would normally cost you $200+ if you bought is.Try this web site out www.lexls.com, it belongs to one of the members here and has a lot of good DIY information on the first gen lexus.
Old 03-22-05, 01:48 PM
YSITIS
YSITIS's Avatar
I appreciate that.
Old 05-08-05, 08:44 PM
YSITIS
YSITIS's Avatar
Default Speedo fixed no too the horn....
My motor was shot in the speedo. Swapped clusters, no problems. My horn is non functional....any suggestions?
Old 05-09-05, 06:57 AM
Lextreme
Lextreme's Avatar
Check the fuse box in your engine bay......
Old 05-09-05, 08:21 AM
YSITIS
YSITIS's Avatar
Fuses are good along with the relays.
Old 05-09-05, 08:59 AM
Lexozz
Lexozz's Avatar
Make sure your cable is plug into the tranny. I had similar problem with ny Cressida years ago and that solved the problem.
gkane
14
07-25-19 06:11 PM
elcolonel
06-22-14 01:53 PM
groverwood
SC- 1st Gen (1992-2000)
18
10-04-12 08:27 AM
Lil4X
03-02-11 10:31 AM
martycone
GS - 1st Gen (1993-1997)
07-03-06 09:10 PM
Quick Reply: Speedometer MPH and horn
