Climate Control Lights
Updating the lighting on my sc300 and really want to change out the "indicator lights" for the climate control to blue. (the lights above the defroster, circulation and AC buttons)
kind of stuck at this point...
has anyone done these before?
also it feels like the board is still attached to something inside the housing, I cant see in there though and dont want to risk breaking anything.
Do I just need to desolder the bulbs from the back of the board or what..might be in a little over my head here?
It can be done man, just finished doing this to my CC on my 2nd gen GS.
looks like your half way there, just unsolder the old ones replace with the same type in a different color, worked for me, I used 3mm LED off ebay in blue, but to be honest I'm gonna change to white cause the blue is a bit to bright for me.
solder them exactly as you see the old ones onto the circuit board. a good tip it to get a multimeter and set it to diode test and make sure you get the positve side into the right slot. let me know how it works out for you.
do you unsolder from the back?? Because I dont see how to remove the black plastic on the front. And in that pic, the board is free from the clips on the side but it still feels like something is holding it in there. I've been told I just need to stop being a betch and it will come out, is this true?
Do you have any pictures of your CC? And do you know what brightness (mcd) your blue leds are?
I am looking at the ones from superbrightleds.com that are 2000mcd which shouldnt be too bright. I also have their 5000mcd white LEDs in my window switches and they arent blinding.
Well to tell you the truth I kinda winged it when it came to brightness etc..lol I saw the colors I wanted on ebay and went for it.. I ordered 3mm and 5mm that's the only thing I paid attention to was the size..
here's some pics of my work in progress, I'm trying different looks but I think I'm gonna go with the white display and change the air circ. button lights to white, that blue is just a little to bright for me to be "on" all the time while the car is running.
Also I changed my alarm light to blue since everything else is gonna be either blue or white.. all this cause my tape deck on the Nak stock radio broke!..lol
wow those are a little bright. look good though. matches your double DIN very well.
I wouldnt change the circ button just yet man. White is most likely only going to be brighter. I have my blue LEDs ordered and they should be here in a couple days and I'll try to get em put in this week and let you know how bright they are.
