[OWI] Sunroof issues GS300
My 2000 GS300 sunroof is acting very strange. It does open and close but only after 40-50 times pressing the button. It moves just a tiny bit with each time I slide the button. Also it wont completely close. Is there a manual switch that I can access to close the sunroof. It has about a 1/2 gap open...
Lexus Customer Service
Hello, it sounds like the motor that controls the sunroof may be failing. Unfortunately, a master switch is not available. We recommend you contact your local Lexus dealer as they would be in the best position to diagnose your concern.
AC Blower Problems
One day my AC was blowing cold air and back and forth warm to cold. The next day it stop blowing period. I was told after having it looked at that the mechanic hooked a power supply up to the blower motor and it worked. Although he would have to charge me $300 to diagnose the problem. He said its probably just a relay. After all the reading im doing it seems like a relay is probably the issue. Can someone please tell me where this relay is so I can change it..
cowboyed, we apologize for you experience. We are not technical however, you can get the information you are looking for from the repair manuals here: https://techinfo.toyota.com/techInfo....toyota.com%2F we hope this helps...
opisdfagjo
Performance & Maintenance
10-21-18 02:24 AM
