Self Restoring Coat "Paint"
I called Lexus on this and they seem to have no idea so maybe I will get a better answer here. I ordered a RCF and wanted to know if you can polish / clay bar / wax the paint? I know at the auto show you had a blue RCF and it was polished and waxed just wanted to see how you care for this paint.
■ Self-restoring coat*
The vehicle body has a self-restoring coating that is resistant to small surface scratches
caused in a car wash etc.
● The coating lasts for 5 to 8 years from when the vehicle is delivered from the plant.
● The restoration time differs depending on the depth of the scratch and outside temperature.
The restoration time may become shorter when the coating is warmed by applying
warm water.
● Deep scratches caused by keys, coins, etc. cannot be restored.
● Do not use wax that contains abrasives.
*: CFRP parts (if equipped) do not have a self-restoring coat
http://drivers.lexus.com/t3Portal/do.../sec_07-01.pdf
warm water.
Lexus Customer Service
Hello Ryanmcd, great question! We do not recommend polishing or waxing your vehicle within the first month of ownership to allow the paint to fully cure. The Self Restoring Paint is only used on certain colors like the Obsidian or Nebula Grey as they are more prone to show scratches. If you order a color that is equipped with the Self Restoring Paint you can wax or polish it gradually. Remember the vehicles used at auto shows are not intended for long time use so we do things to those cars that may differ from normal operation. We hope this helps. Congrats on the RCF! We look forward to seeing pictures when you take delivery.
Also it's great to have you guys answer questions! and thanks
I would also like to ask how thick in term of microns is the "self restoring" coating? If someone was to do a light to medium polish to remove some random scratches, will that remove that "self restoring" property in that polished area?
The answers to these questions are a great concerns to detailers. Thanks.
2. If yes, when can one apply XPEL film to protect the front from rock chips? AndyL implies: asap after delivered.
3. Since the car will be on a ship for a month (special order with CF TVD) isn't that enough time for the paint to cure? AndyL says: YES.
Thanks
Rick
Thanks.
Paint is already fully cured for any car before the car gets out of factory. Ask any car detailing shops and body shops and they will tell you the same thing. Otherwise, it will be a huge problem for many detailing shops -- new car prep is a common service from respectful detailing shops. And FYI, Lexus dealerships in Japan has a dealer option listed called body coat for new Lexus vehicle delivery.
Same as many dealerships in North America which offer various sealant or coating packages.
http://lexus.jp/models/rcf/specifica...are/index.html
Some background info --
http://paultan.org/2009/10/02/lexus-...#ixzz0SjlHWJU0
And there is another article from Toyota.jp which talks about their restoring coat. (sorry it is in Japanese)
http://www.toyota.co.jp/jpn/company/...ls_window.html
And to speed up the self-restoring, heat is required. If you pour hot water of 80C, you will speed up the healing process as described in this article (sorry in Japanese)
http://sun-detailing.com/?m=20140305
Also note self-restoring paint applies to all colors of RC, RC F, NX, IS, GS and LS in some countries such as Japan.
You said SOME COUNTRIES. So are all the RC-Fs for the USA self-restoring coated?
Some countries refer of Japan, UK, Hong Kong, etc. But I don't check the info for RC-F. Probably it applies. But I am sure It applies to IS.
I think I may just polish it off at the start to seal the paint, It must be good stuff if Lexus does not even know about it and it's only on a few colors. My worry is people that are going to put a seal on the car off the bat, that may cause issues down the road.
And any car coating won't look good unless it is followed by paint correction. In most cases, a new car condition requires no heavy polish. Maybe some RIDS (random isolated deep scratches) and that is it. So you may use very mild polish for final finishing/jewelling prior to coating. It probably shaves off 0.5-1 micron of clear coat which won't hurt the self-restoring coat.
My logic is -- Lexus body coat (it is silica-based coating,according to Japanese brochure or lexus.jp )is published on Lexus.jp as a dealer option and it is done prior to new car delivery. Minimum polishing must be done prior to coating. And it costs much than DIY coatings.
