3IS having trouble changing reverse lights =(
Old 08-10-14, 11:25 AM
xxwhosnxt
xxwhosnxt's Avatar
Default 3IS having trouble changing reverse lights =(
I'm trying to install led reverse lights
i removed the lining in the truck around the tail light but can't see what i need to pull out to remove the reverse light.. do i have to pull off the entire taillight ?
HELP
Old 08-10-14, 01:48 PM
tkr128
tkr128's Avatar
There should only be one bulb socket (should be white) on the trunk lid for each side. Just twist it counterclockwise and it'll come out. Remove the old bulb and stick the new one in and twist it back into the socket. Check page 441 of the owner's manual.
Taillight does not need to come out. Hardest part for me was taking out the lining.
Old 08-10-14, 02:02 PM
xxwhosnxt
xxwhosnxt's Avatar
the only thing i saw was a black wire heading into the taillight
Old 08-11-14, 09:10 PM
WiLz
WiLz's Avatar
Just to make sure, you are looking on the trunk LID, correct?
Attached Thumbnails 3IS having trouble changing reverse lights =(-reverse-light.jpg
Old 08-12-14, 01:55 AM
Mesh704
Mesh704's Avatar
I have changed mine to LED !! I took a pic for u to see the diff !!
https://i.imgur.com/Ds5LQ93.jpg
https://i.imgur.com/QxogGLh.jpg
Old 08-12-14, 08:27 AM
IS3F
IS3F's Avatar
Looks so much better! Where did you get the bulbs from?
Old 08-12-14, 01:33 PM
xxwhosnxt
xxwhosnxt's Avatar
wowwww thats why !!! i thought it was in the trunk lmao
thank you !!!
Old 08-17-14, 12:47 AM
l5JLlll
l5JLlll's Avatar
lol thats my Car with the Reverse LED on them!
I got them from HIDPowerhouse.com
http://hidpowerhouse.com/shop/maxrs-...everse-leds-2/
they have 3 different brightness levels the MaxRS Super White Reverse LEDs i used is the best one out of the 3 they have
Old 08-17-14, 12:54 AM
Mesh704
Mesh704's Avatar
Thanks for the respond 👍
Old 08-17-14, 04:02 AM
silvaIS
silvaIS's Avatar
HELP
hey were you able to do it? I wanted to see the light output in person. I changed led bulbs in my previous cars and they always seemed to have dark spots and poor visibility. where in NY are you ?
Old 08-19-14, 05:54 PM
xxwhosnxt
xxwhosnxt's Avatar
hey man yes i did it, its very easy and bright
im in queens ny !
Old 08-20-14, 05:48 AM
Kwik8276
Kwik8276's Avatar
Can someone tell me the bulb number for the reverse lights please
Old 08-20-14, 11:06 AM
tkr128
tkr128's Avatar
It's a 921 bulb. I got a set of these: http://www.vleds.com/5k-white-15-led...79-1-pair.html
boostinsc
09-25-15 08:40 PM
Infamous3
02-26-14 08:33 AM
SonyHome
01-12-14 08:03 PM
The G Man
04-17-08 11:53 AM
dsouth
Lighting
07-08-07 11:05 PM
Quick Reply: 3IS having trouble changing reverse lights =(
