Good spot to place aftermarket HID ballast?
OK so I installed an HID kit the other day. I discovered what I believe is the perfect spot to mount the ballast and it's under the headlight. There appears to be a space where an OEM ballast would mount so this is where I mounted the aftermkt as well.
Has anyone else placed their aftermarket ballast here? The bottom of the headlight is made of plastic. Does the ballast get really hot and can actually damage the plastic? Here's a pic of where I placed the ballast. Lmk. Thanks.
Thanks. I'm guessing I may be one of few or the only one whos mounted the ballast in this location?! I hope it turns out ok. Keep everyone else posted should it fail..
^Alright then. Which kit do you have? I got the pricier kit from VLEDs in hopes that I don't have to change the ballast/bulbs as often as the cheaper kind as I've found are likely to fail more often..
