Frozen Nav Screen (newb)
Old 10-01-14, 11:29 AM
5nX37
5nX37's Avatar
Default Frozen Nav Screen (newb)
Hello. New to the Lexus scene. Made a jump from an '03 Audi A4 1.8T Quattro to an '06 IS350 Crystal White with 109k miles. I'm loving the past couple of weeks of having this car. But just this morning I faced the dreaded and unwanted frozen Nav screen. ARGHHH! Anyhow, just wanted to get an idea on what others have done to deal with this issue. I hope this isn't an indicator of how owning this car would be. TIA.
Old 10-01-14, 12:07 PM
Gville350
Gville350's Avatar
Details needed about the specifics; does it freeze on the Lexus entry logo? Do you usage of the button around the screen itself?
Old 10-01-14, 01:09 PM
See5
See5's Avatar
there is a DIY topic for fixing it I just fixed mine .
Old 10-01-14, 04:28 PM
5nX37
5nX37's Avatar
It goes past the Lexus entry logo. The buttons surrounding the screen work fine. It's really my only way of controlling the audio and a/c (auto mode only). It's when I try to push the radio presets, a/c fan speed, sound controls, and such is where it does not work.
Old 10-01-14, 04:30 PM
5nX37
5nX37's Avatar
Seen that. Did you go fixing the wiring route or replacing just the screen?
Old 10-02-14, 12:22 PM
Gville350
Gville350's Avatar
Sounds like the digitizer needs to be replaced.
Old 10-02-14, 01:19 PM
skoota500
skoota500's Avatar
Just follow the DIY on here, also the video is on youtube. I fixed mine a couple months ago. Hardest part was removing air vents haha.
Old 10-02-14, 02:03 PM
5nX37
5nX37's Avatar
Ok. You're referring to this I'm assuming; http://www.ebay.com/itm/USA-LEXUS-IS200-IS220-IS250-IS300-IS350-NAVIGATION-LCD-DISPLAY-TOUCH-SCREEN-/221405873862?pt=LH_DefaultDomain_0&hash=item338cd186c6.
Old 10-02-14, 02:08 PM
5nX37
5nX37's Avatar
Seen that just last night. I think the owner went and did the rewiring/"resoldering" route. I'm debating whether to replace the entire screen (digitizer?) or rewire... I'm guessing rewiring would cost much less than replacing the whole screen, but it would be more tedious.
My question is, which fix would be more permanent or last longer: rewire or screen replacement?
Old 10-02-14, 02:11 PM
5nX37
5nX37's Avatar
Thanks for the replies so far. Audizine forum has helped me through A LOT of issues with my A4. I get the sense that members in this community would be just as helpful. I appreciate you chiming in to help out a 2IS newbie.
Old 10-02-14, 03:06 PM
Gerb
Gerb's Avatar
how much u buy it for at 109k miles
Old 10-02-14, 08:04 PM
scott1256c
scott1256c's Avatar
No, that is a touch screen. Search for
7.3'' Touch Screen Digitizer Panel Replacement
on ebay. They are $30-$50 or so. I'm not saying that will fix your problem, but that is a digitizer. You may need to buy a new touch screen, but I'd start with the diy fix, then try the digitizer, then the touch screen. Unless you are in a hurry and can't wait for the shipping, or don't want to take apart the dash 3 times, then just try the touch screen, but even that isn't guaranteed to work. But I think Gville350 is correct in that it is the digitizer. The diy fix is to fix the digitizer. My fix has lasted a few months now with no problem. I know if mine has problems again, I'll just buy a new digitizer.
Old 10-02-14, 10:47 PM
5nX37
5nX37's Avatar
Got it. I found out little more about the difference between the 2. I think I will resolve to replacing the digitizer. It just seems to be more of a durable fix. Now, for those that replaced the digitizer, I noticed some peeled off their old one, then adhere the new replacement. Then there are those that kept the old one intact, and adhered the new one over the old one. Which way is best?
Old 10-03-14, 06:20 PM
Gville350
Gville350's Avatar
If you don't want to have to go through the process of the old digitizer removal and new install, you can just get a new screen like what you posted above (except look for a cheaper one; that one is double than the one I got). The new screen already have the new digitizer on it.
JerryWest
08-30-17 07:34 AM
GetKinetic
RC F (2015-present)
03-06-17 01:13 PM
Magellan
02-06-17 11:43 AM
CsKWarEd
07-19-07 03:20 PM
GS3Tek
GX - 1st Gen (2003-2009)
07-24-05 09:04 AM
Quick Reply: Frozen Nav Screen (newb)
