Will these tires work on my 2008 Lexus is250
Old 07-04-14, 10:25 AM
lexuslexky
lexuslexky's Avatar
Default Will these tires work on my 2008 Lexus is250
I just put 4 new yokohama avid ascends on my 2008 Lexus IS250. Since then I am getting a vibration in the car and some vibration in the steering wheel. Someone told me these are made for high performance cars and not touring sedans and would cause the vibration. Other told me to check the toe on my alignment, which when the tires were put on they also did an alignment at that time. Any suggestions-opinions of what is causing this would be appreciated.
Old 07-04-14, 10:29 AM
Gville350
Gville350's Avatar
Check that all of the lug nuts are on tight. Other than, have the tire place re-balance the tires.
Old 07-04-14, 11:32 AM
WylieKylie
WylieKylie's Avatar
You probably should stop listening to the first friend when it comes to car stuff. 1st of all a set of all-season (AKA no-season) tires have no place on a "high performance car". 2nd of all, ALL tires need to be balanced, and that goes double for a "high performance car". Imagine a Ferrari at 190mph with out of balance tires, it would take less than 2 minutes before things started breaking.
As far as the 2nd friend, toe can make the car twitchy, but it won't make the car vibrate. As mentioned by Gville re-balance the tires.
Old 07-04-14, 11:47 AM
darkdream
darkdream's Avatar
Those tires are specifically labeled touring. They may dampen vibration, but your traction will suffer in the wet and the dry. Your braking distance will increase, your car may brake traction. Vibration might be due to some other factor and getting all season touring cars will just mask it. My car's steering wheel is void of any vibration and I am running PSS.
Old 07-04-14, 04:56 PM
Mike_1GO
Mike_1GO's Avatar
go back to the tire shop that did the mounting/balancing and have them rebalance free of charge.
Old 07-07-14, 02:44 PM
lexuslexky
lexuslexky's Avatar
So other than poor traction should the
tires be ok for my car?
Old 07-10-14, 07:14 PM
lexuslexky
lexuslexky's Avatar
Ok I had the tires balanced again and it did help but there is still a bouncy feel when driving. Any ideas on what might be causing this?
Old 07-10-14, 08:31 PM
Sffd103
Fire Slayer
Sffd103's Avatar
could they be overinflated?
Old 07-12-14, 11:40 AM
sktn77a
sktn77a's Avatar
If the old tires didn't do this, then there's a problem with the tires (out of round) or the installation (balance). Go back to the place that installed them and tell them to fix the problem.
mdk77
Chicago Lexus Club
07-23-19 05:54 PM
RYAN7585
09-20-18 10:22 AM
junior818
Wheels, Tires & Brakes Forum
12
12-14-14 08:13 PM
lexuslexky
IS - 1st Gen (2001-2005)
07-05-14 02:43 PM
hmkim
05-11-10 08:24 AM
Quick Reply: Will these tires work on my 2008 Lexus is250
