Need help. 08 IS350 stalling after valve timing recall
Old 06-16-14, 02:40 PM
jetpig
jetpig's Avatar
Thanks for all the help! I will report back when I pick up the car!
Old 06-17-14, 07:52 PM
jasonr
jasonr's Avatar
I had exact same trouble. Dealership told me to change the fuel pump. But then after searching few forums i found some solution and told dealer. They checked again and it was a minor problem. I had more codes but i cleared them, then these came back again..
Here is the problem I had and result from Dealer.
Attached Thumbnails Need help.  08 IS350 stalling after valve timing recall-untitled.jpg   Need help.  08 IS350 stalling after valve timing recall-car-result.jpg
Old 06-17-14, 08:01 PM
Gville350
Gville350's Avatar
^Loose grounds I've read about on here have been the cause of a few different odd issues. Hope that might fix your issue too!
Old 06-18-14, 04:19 AM
jetpig
jetpig's Avatar
Interesting. What gets my attention is how the problem went from an eyebrow raise annoyance to full blown car won't run over a period of 3 weeks. I have a lot of mechanical experience with cars and any fuel pump I have ever been around doesn't fade out. It either works or it doesn't. That is what makes me wonder as well. This sounds more viable.
I contacted Lexus Corp and am suppose to hear back tomorrow on their solution. I am still looking for an answer from you folks if anyone knows as to the proximity of the pump in relation to the work done on the VVT recall. If the pump is unplugged, removed or is in any way manipulated during the recall work. Gville, the pic's you posted help a lot but I can not exactly tell where on the engine the pump is (front, rear, L, R) without the car. Please keep it coming all and thanks! Tons of help here.
Old 06-18-14, 05:53 AM
B16da9
B16da9's Avatar
Hmm I wonder where this ground on the ECU is located. My car has 14k miles and I sometimes get a small sputer from it which goes away quickly.
Old 06-20-14, 04:18 AM
jetpig
jetpig's Avatar
Ok great news to report. Lexus Corporate called, said yes they believe the part failed prematurely. They cover all parts, we cover labor. This makes me really appriciate the Lexus brand! A huge thanks to those on this site for insight and help.
Old 06-20-14, 06:11 AM
jsh139
jsh139's Avatar
That is great news, indeed! And all it took was a phone call. Great customer service. It's acts like this that keep people coming back. Glad they are helping you out.
Old 06-20-14, 06:35 AM
B16da9
B16da9's Avatar
That's great to hear especially since the cost of the part is almost 1k on Sewell with CL discount.
Old 06-21-14, 10:43 AM
Gville350
Gville350's Avatar
This pic should help :
Well, that's definitely better than nothing; glad to hear they stepped up on this for you!
JDBIII
08-10-24 08:53 PM
jessica17
05-11-15 06:23 AM
yotaholic
04-02-12 07:45 PM
Stun350
09-27-10 01:38 PM
Quick Reply: Need help. 08 IS350 stalling after valve timing recall
