Does your is350 burn oil?
Old 04-28-14, 11:09 PM
kiryu
kiryu's Avatar
Default Does your is350 burn oil?
Hi all I have a 2007 IS350 with under 120k miles....Just had my first oil change about 4000 miles ago, 5w30 mobile 1 with toyota filter, and today I received an engine oil low warning light! Freaked me out so I bought some oil and poured 1 qt in
I used to change oil every 7-10k miles on the previous acura, with mobile 1 filter and oil, drove like a charm.
Figured I should at least be able to last 5000 miles for the lexus.....
Does your IS350 burn engine oil? is that a common thing? My mechanic says it's common for toyota and nissan engines to burn oil. Is there anything I can do to reduce oil burning?
Thanks for any insight!!
Old 04-28-14, 11:45 PM
jasonr
jasonr's Avatar
My is350 burns gas lol. Anyway
if you use regular oil then change it around 3000-4000K. Toyotas used to be every 3000k
New IS350 says 5000K. But they do recommend you to check every month, Incase u are driving under different conditions…
Old 04-29-14, 01:49 AM
jnguyenyo
jnguyenyo's Avatar
Had the same problem, thought it was a leak but it wasn't. Just topped it off with more oil. I guess you just gotta keep some handy
Old 04-29-14, 07:05 AM
06350F
06350F's Avatar
My LS motor burns oil at 44k miles. It's common in a lot of cars to consume oil. Like others have said it depends on conditions. Motors normally use oil die to hear soak and so on. Not sure if an entire quart is common but expect oil to be loaded between changes. My 06 350 is a later year build, I try to go every 3k for changes.
Old 04-29-14, 08:00 AM
SC400MAN
SC400MAN's Avatar
My wife's 2007 IS350 only has 31,000 miles so I have never added oil to it. I change the oil every 6 months. I have a 1997 Supra with 149,000 miles and (knock on wood), I have never needed to add a drop of oil in between changes to it! I has never been noticeably down.
Old 04-29-14, 08:13 AM
tboo72
tboo72's Avatar
133k on my 06 IS350 and it doesnt burn any oil.
Old 04-29-14, 08:29 AM
getafewliv
getafewliv's Avatar
No oil burning here.
My old Acura TSX used to burn lots though.
Old 04-29-14, 08:46 AM
pheonix72
pheonix72's Avatar
It is normal for engine with high milage to burn oil but make sure you keep and eye for excessive burning.
My 2006 is350 with 110k burns about 1/2qt every 3-4k miles. My oil change interval is 7.5k with Mobile 1. I just filled to the max line (on the dip stick just in case I forget to check the oil level).
My old beater RSX Type S was burning oil like crazy (a quart every 2.5k). I switched to Castro Synthetic and it helped a little bit.
Old 04-29-14, 09:16 AM
Jaytea
Jaytea's Avatar
Certified lexus tech friend was changing my oil. Went about 8000 km before oil change. Did not burn any. He said I could go 10k km easily on fully synthetic... Mind you my car is just rolling over 90k km mark.
Old 04-29-14, 11:55 AM
darkdream
darkdream's Avatar
All cars burn oil, some just alot more than others. I have never noticed any measurable amount of oil burned.
Old 04-29-14, 12:06 PM
Gville350
Gville350's Avatar
^Yeah, to be technical; but no measureable difference on the dipstick is what I'm sure the OP meant.
I've owned my '06 IS350 since April 1st 2011 (31k miles), and I've NEVER noticed a drop in oil level in-between oil changes. Now at 75k miles.
Old 04-29-14, 01:00 PM
NYKnick101
NYKnick101's Avatar
Burning oil is one thing. All cars burn a little bit of oil here and there but it shouldn't be enough to cause a low oil CEL light. Then that means you may have an oil leak. I would check around the ground if you park your car for extended periods of time where oil leaks from. A common place where there are oil leaks are the oil filter housing in front of the engine/oil pan.
Old 04-29-14, 02:35 PM
FSportIS
FSportIS's Avatar
How can you tell if it burns oil? Does some light turn on? Any smell or noise??
Old 04-29-14, 06:04 PM
Gville350
Gville350's Avatar
^Usually it is blue smoke from the exhaust and measureable oil loss.
is250fsprt
03-08-15 10:57 AM
racsos222
03-22-14 07:14 PM
xcharlesy
08-01-11 09:37 PM
x2mkx
02-16-06 10:16 AM
Quick Reply: Does your is350 burn oil?
