Ugly rock guards
Old 02-02-14, 10:40 AM
3sm1l
3sm1l's Avatar
Default Ugly rock guards
Hey there!
I need ideas about what can i do to fix these rock guards on my IS. I don't know if there's a way to remove them and replace them with new ones (Does Sewell sells them?)
Ideas welcome!
Old 02-02-14, 05:57 PM
3sm1l
3sm1l's Avatar
No one?
Old 02-02-14, 06:25 PM
valeoray
valeoray's Avatar
Why not buy a sheet of new clear guard? Peel the old one off and use it to trace a new one out of the new sheet. Then wax the crud of the paint and apply the new piece on.
Old 02-02-14, 07:58 PM
firelikeiy
firelikeiy's Avatar
Wow, those look really bad. I imagine Sewell would sell them. You can also have a clearbra installer replace them with larger custom ones that provide better coverage. Probably would cost under $100. I would use 3m clearbra material.
EDIT: I just noticed where you are located.
You can buy the 3M material off of Amazon and install it yourself. You can buy the 3M material off of Amazon and install it yourself.
It will come in a roll so you will have to cut it to your liking and then install. You'll need a small squeegee, baby soap (like johnsons &johnsons) and a spray bottle. Fill the spray bottle with ro or deionized water and a couple of drops of the baby soap. Pull off the old stuff and remove any adhesive with rubbing alcohol. Spray the area that you are going to apply the new material to with the water/soap mixture and soak your hands with it also so that your hands do not stick to the new film. Peel that backing off the new film and spray the sticky side with the soap/water mixture. Apply the film to the car keeping the area wet and work out any bubbles. If there are any small bubbles left once you are done, they may go away in a couple of days.
NOTE: Do NOT apply wax to the car before installing the new material as it will cause it to yellow. You can apply wax over the new material once it is installed but you really don't need to.
NOTE II: Do not add too much soap to the water. You do not want bubbles to form when you spray the car with it. You literally need 1-2 drops of soap per cup water.
Old 02-03-14, 11:52 AM
nosurprise
nosurprise's Avatar
Why not just remove it? I don't have one on my car and don't notice any rocks scratching that part.
Old 02-03-14, 12:02 PM
13IS250C
13IS250C's Avatar
+1 Just remove it.
Old 02-03-14, 12:14 PM
Gville350
Gville350's Avatar
^^I agree! I have zero problems with rock chips in that area. But right below that area on the side skirt I've got ALOT of rock chips. Boo!
Old 02-03-14, 01:06 PM
Raybean
Raybean's Avatar
same all my mini rock chips meet to happen on my side skirts
Old 02-03-14, 04:58 PM
3sm1l
3sm1l's Avatar
Thanks for your replies guys!
But don't all lexus comes with them? do your cars don't' have them?
Old 02-03-14, 06:58 PM
firelikeiy
firelikeiy's Avatar
All cars come with them. That is the area determined to receive the most rock chips. The new IS has them as well but they are 4 times as large!
Old 02-03-14, 08:35 PM
Sffd103
Fire Slayer
Sffd103's Avatar
just take them off for now at least. They look horrible. coNo!
Old 02-09-14, 06:22 AM
3sm1l
3sm1l's Avatar
UPDATE:
Guys, I tried to remove them but they are very hard to! I can't make them come off in one piece, every bit that i grab just breaks. At this point i'm considering in covering them with another Vynil, like carbon fiber or whatever.
What do you say?
Old 02-09-14, 09:48 AM
Allan1
Allan1's Avatar
Heat gun/hair dryer will help
Old 02-09-14, 01:47 PM
Gville350
Gville350's Avatar
^Yep! I've seen someone on here post a link to Sewell's website before for those things, so I assume they're available.
Old 02-09-14, 07:06 PM
3sm1l
3sm1l's Avatar
^^ Yup, found 'em on Sewell, US$ 10.5 each, Will try the head gun method as Allan described.
GoldieLex
Automotive Care & Detailing
17
06-29-14 09:58 PM
ChanceG
05-06-13 06:09 PM
istundra
09-05-06 08:42 AM
prjctSC300
SC- 1st Gen (1992-2000)
12-12-05 08:42 PM
Quick Reply: Ugly rock guards
