Who installed Lowering springs/coilovers them self?
Old 01-12-14, 02:22 PM
is250fsprt
is250fsprt's Avatar
Default Who installed Lowering springs/coilovers them self?
I just got my F sport springs shipped to me today. I was going to have a Lexus dealership install the springs for me but I'm not sure if they will install a customer part. Beside that they might charge an arm and a leg. Anyone recommend a DIY on this? I've done Integra and Civic in the past but never a Lexus.
Old 01-12-14, 02:23 PM
Toxicxk23
Toxicxk23's Avatar
If you have experience doing spring installs then you'll be fine. I say go for it and save yourself some money!
Old 01-12-14, 04:37 PM
whitebeast
whitebeast's Avatar
+1 for DIY
You have done it before so get it done this time as well.
Old 01-12-14, 04:43 PM
Gville350
Gville350's Avatar
If you've done them on a Civic, then there's NO difference. The hardest part will be removing the trunk liner to access the rear shock tower bolts.
Old 01-12-14, 04:57 PM
whitecel
whitecel's Avatar
DIY it's simple. Did it myself. There's a link to a DIY, but too lazy to look for it right now. That and I have the stomach flu so I'm kinda busy at the moment
Old 01-12-14, 05:13 PM
e46m3lol
e46m3lol's Avatar
Just do it yourself. Took me longer to actually adjust the coilovers to the perfect ride height than what it took me to install them. ha ha
Old 01-12-14, 06:38 PM
g2bme
g2bme's Avatar
If you don't want to DIY, just saving some time, depending on your location, here in SoCal these a new Lexus master tech that opened his own shop in redondo!
Old 01-12-14, 08:15 PM
ChiLexus10
ChiLexus10's Avatar
I have. Took a 2hrs to do the coil overs. Honestly it'd very easy. One of the easiest I've done in awhile
Old 01-12-14, 08:31 PM
NYKnick101
NYKnick101's Avatar
I would sometimes time myself on how fast I can do it. I've done all 4 corners in an hour 34 mins start to end.
Old 01-12-14, 10:11 PM
metaleckz
metaleckz's Avatar
I did my very first coilover install ever on my lexus and took me about 4 hours. I took my time ! Lol
Old 01-12-14, 10:16 PM
is250fsprt
is250fsprt's Avatar
anything you guys would have done differently to speed up install process. Any tip on how to remove trunk cover?
Old 01-13-14, 09:06 AM
Downtuned
Downtuned's Avatar
I DIY with my H&R Springs on my IS250 based on this amazing guide:
https://www.clublexus.com/forums/sus...our-isx50.html
keep in mind, i have never undertaken a project like this before, and i am by no means a mechanic, and i did it myself.... however! it was fairly difficult for me. if you have the right tools and have experience with this kind of stuff, then you will be fine. the trunk cover is fairly easy to remove, that is the easy part. getting the control arm down to get the spring in and out is the hard part. Good luck, and make sure to PM me if you have any trouble, since I was a newb to the process and was successful, I can be more detailed on the do's and dont's, it was quite a learning experience.
Old 01-13-14, 09:08 AM
Downtuned
Downtuned's Avatar
done differently: had a pipe wrench from the start, wished I had a better jack, wished i disconnected my abs chord from my brake before i ripped it off accidentally with my crowbar, wished i didnt take off the upper bolt (with the ball bearing) of the upper control arm for the front wheels. other than that, it was pretty straightforward.
Old 01-13-14, 09:10 AM
Downtuned
Downtuned's Avatar
fyi, if you do not have a nice big hydraulic jack, make sure you have at least 2 floor jacks, you will need 1 to lift your car, and one to take the pressure off the control arms when tryin to get the bolts out. also, do not hammer any bolts on the threaded ends too hard, you do not want to mess up any threading, otherwise you're gonna have a bad time.
aTeAse
Suspension and Brakes
04-15-14 05:59 AM
SkillHill
05-19-09 10:05 AM
LILDANTE79
07-23-08 12:17 AM
caymandive
09-25-07 03:46 PM
Quick Reply: Who installed Lowering springs/coilovers them self?
