Can I run stock 18" rear staggered on front?
Old 09-17-13, 03:47 PM
NorCalIS
NorCalIS's Avatar
Default Can I run stock 18" rear staggered on front?
So I had to take my front wheels off, doing a little work on them, and I was wondering if I could take the rear 18's from my OEM staggered setup and put them on the front, just not sure if the offset would be ok in the front.
Old 09-17-13, 10:12 PM
panda08
panda08's Avatar
offset of the OEM rear 18s is 50, OEM Front 18s is 45. I think itd be okay. try to hand tighten a lug nut and rotate the wheel slowly?
Old 09-18-13, 12:13 AM
Snyperifle
Snyperifle's Avatar
yes you definately can
Old 09-18-13, 10:47 AM
Gville350
Gville350's Avatar
When you have those 18x8.5 wheels up front, what will be out back? Same size OEM wheels? If so, you're setup will be "square" and will be fine.
Old 09-18-13, 12:00 PM
kickin8
2IS/2RX/4RX
kickin8's Avatar
OEM rear tire will rub?
Old 09-18-13, 04:10 PM
Jeff Lange
Keeping it Real
Forum Moderator
Jeff Lange's Avatar
The wheel can definitely fit without issue, I would be concerned about the tire size however, as the rear tires are almost an inch taller than the front and running that size will most likely rub.
Jeff
Old 09-18-13, 06:19 PM
Chuy250
Chuy250's Avatar
The dealer told be back in 06 not to do that, but I don't see what.s the problem, I would do it if i had to. I don't know if it will rub as other members are saying.
Old 09-19-13, 12:34 PM
NorCalIS
NorCalIS's Avatar
Thanks for the responses guys!!
Have my other wheels still on the back, they are 9.5 in the rear, so still staggered.
Jeff
Ha! Rub! My best friend in the whole world, I can never go anywhere without rub it seems! No, in all seriousness it will rub, but I turned my coils up a hell of a lot, so hopefully it wont be too bad. I don't really need to drive it all that often while my I'm working on my front wheels so I'm not too worried. Thank you for the valuable info though, seriously appreciate it!!
13Tacoma
09-08-14 06:50 AM
CaptDank
09-02-14 04:22 PM
suka4thong
03-29-10 07:34 AM
sincityIS
06-16-07 09:41 PM
Quick Reply: Can I run stock 18" rear staggered on front?
