iJDMToy Decoders - DRL
Old 06-27-13, 08:33 AM
jimjaix
jimjaix's Avatar
Originally Posted by 1Clean06IS
^ how's it holding up, any worries a out heat issues?
Ya I have the same thought cause the decoder is extremely hot.
Old 07-01-13, 06:37 AM
BigJ
BigJ's Avatar
No issues so far. It was 105 degrees outside on Saturday, and I drove for 2 hours in the middle of the day, so that was probably a good test.
Old 07-01-13, 09:33 AM
ApexiIS250
ApexiIS250's Avatar
Got mine in the mail on Saturday. About to install these this week. I really like the heat wrap tube idea. Gonna have to give that a try.
IL
Old 07-01-13, 11:34 AM
koc88518
koc88518's Avatar
Hey I've purchased the regular DRL with Decoder for my setup, but my fuses keep blowing up and it never turns on. Anyone have any idea what the problem might be ?
Old 07-01-13, 03:13 PM
BigJ
BigJ's Avatar
make sure you have the polarity correct on the connector between the car and the decoder. (just make sure the red wire is going to the red wire) My connectors were bakwards from iJDM, so I switched the pins.
Old 07-08-13, 02:49 PM
koc88518
koc88518's Avatar
That did the trick, it was little hard taking out the pins but after everything its so worth it DD
Now to change the Parking light bulb, i hate seeing the orangish/yellow collor next to my LEDs :P
Ordered the Blue Led 5smd will post with pictures after!
Old 06-09-18, 06:33 AM
abayacal
8th Gear
abayacal's Avatar
Originally Posted by BigJ
Just got home and popped the decoder boxes open (see attached pics). First things first, the giant warning label on the back of the box hides a Phillips head screw which can be removed and the box opens right up. I'm glad I looked for the presence of a hidden screw before I tried to pry it open, makes things much easier. As you will see the circuit board and capacitors inside are considerably smaller than the box itself! In order to keep things protected from short circuiting I planned to get some heat shrink tubing from Lowes to slide over the electronics before putting it inside the light housing, however all they had was really small diameter stuff in stock, so I'll hit up Home Depot tomorrow, I know for a fact they have the big stuff there. Once I get the tubing on to protect the electronics I'll try stuffing it all inside the DRL side of the housing, and from the looks of it we should be in good shape.
I'll post up more pics tomorrow as I progress...
How's your setup been holding up with the decoder box inside the dust cover? Any overheating issues?
Old 06-09-18, 07:19 AM
MikeFig82
MikeFig82's Avatar
I did the same as OP posted. Been going on 3 years now no issues. Except that I used the full cree LED version 50W. Which I think has 10 bulbs only. They are about 5K HID equivalent, and extremely bright. The new 80W version has 16 bulbs. It's actually way cheaper than before, and I'm thinking of getting them. Since they'll be a tad brighter. Also for the IS you'll need the R4 decoder from ijdmtoy. Follow OP's instructions when installing.
They discontinued it and only offer the 80W version now.
http://store.ijdmtoy.com/Max-80W-CREE-LED-Fog-Lights-DRL-Lamps-p/40-34x-cree.htm
genaos11
12-16-11 02:43 AM
linhqt
04-01-11 08:10 PM
kyang91
11-15-09 10:36 PM
Hideyoshi
Lighting
11-16-06 06:46 PM
Quick Reply: iJDMToy Decoders - DRL
