2012 LED headlights and tailights on a 2007 IS350?
Are the 2012 LED headlights / tail lights a direct replacement for a 2007 IS350? I have HIDs already but I really like the LED DRLs and was hoping it would be an easy swap.
the headlights are easy bro...remove bumper takes 15 mins max to remove and pull out the lights...after that you just wire the lights which is on here or i can direct you...which should take a max 5 mins each light and then put them back in and the bumper back on. A grand total of maybe a hour...
As for the tail it's plug in a get the harness which you will need for the park light I believe...which is maybe $20 oem. Easy work and save yourself money.
New member here. I have a 2007 IS250 Rwd..does all this apply to my model as well? Looking to buy some 2011-13 headlights as well. I dig the led DRL strip.
yes true for all because 2011 2012 they stopped making afs feature in headlights, so thats why you will lose that feature
about $200-250 for install
I'm not sure about that as my 2013 LED headlights have the AFS motors installed in to the back of them. I believe you need to switch up a few wires and should be good.
