Led problem
Old 10-20-12, 01:55 PM
my1s250
my1s250's Avatar
Default Led problem
I have the ijdmtoy perfect fit led for interior ... I have both install but for some reason the back doesn't turn on wayne I open the door.
Old 10-20-12, 02:14 PM
imherenow
imherenow's Avatar
did you try flipping sides??they have to be with right polarity for it to work. Or you could have blown fuse. check to make sure the fuse are working
Old 10-20-12, 04:49 PM
es808
es808's Avatar
Yes...try flipping it. LED bulbs are polarity dependent. If you put them in one way and they don't work, flip them and try again. Otherwise look at the wires on the bulb and make sure that they're straight and making contact with the electrical socket blades.
Good luck!
Old 10-20-12, 07:58 PM
my1s250
my1s250's Avatar
Yes they both light up when I open the door , but when unlock the door only the rear light up...
Old 10-20-12, 09:21 PM
es808
es808's Avatar
For the front overhead lights, is the button marked "door" pushed in? Maybe you pushed it while you were changing the bulbs...
Old 10-20-12, 09:31 PM
CLIS250
CLIS250's Avatar
doesnt the front door button control both the front and rear domes? thats how it is for mine.
Old 10-20-12, 09:35 PM
my1s250
my1s250's Avatar
everything is working fine just when you unlock the door the front and back supposed to light up but for some reason the rear only light up ....
Old 10-20-12, 09:36 PM
es808
es808's Avatar
I think they do but I'm just having him try something. It's a little confusing about what exactly is going on since they both light up when the door is opened.
my1s250, when you say "unlock the door only the rear light up" you're unlocking the doors and not opening them? Or you're opening the rear doors only? Please explain....
Old 10-20-12, 10:22 PM
my1s250
my1s250's Avatar
Yes exactly just unlock with all door still closed
Old 10-20-12, 10:37 PM
neomedic
neomedic's Avatar
I also notice this issue with ijdmtoy leds for my Audi S4. I then switched over to VLEDs. The problem is gone. So I think it's the LEDs. Now I run VLEDs on both my Audi and IS350. Having seen both types of light...subjectively I feel VLEDs are of better quality.
Good Luck
Old 10-20-12, 10:38 PM
CLIS250
CLIS250's Avatar
Good Luck
Agreed May cost a little more, but running JLC and VLED's on my cars.
Old 10-21-12, 01:08 AM
ISCjonny
ISCjonny's Avatar
you have 3 194 bulb sockets on the front dome... which one did you plug into? If i remember correctly from my sedan days, tap the middle one. When you unlock the doors only the middle bulb turns on. When you open the doors, all 3 turn on. Same thing for the back dome lights.. there are 2 festoon sockets. 1 turns on when you unlock, and both turn on when the doors are open.
Hope that helps.
Old 10-21-12, 12:11 PM
my1s250
my1s250's Avatar
Hope that helps.
Yes!!!! That help a lot everything is working as it should now
Front led should ve in the middle socket and rear should be the socket toward the front...
NotFasty
12-17-18 12:57 PM
akoster
03-10-18 09:55 AM
imherenow
41
10-14-13 02:51 PM
potatoman
01-06-11 12:07 PM
mpcguru
Lighting
07-27-04 12:25 PM
Quick Reply: Led problem
