grrr the rattle!!
Old 03-08-12, 08:55 AM
mixa86
mixa86's Avatar
Default grrr the rattle!!
I got this car few weeks ago my 2006 IS350, love the car over all but....... maybe i am spoiled coming out of a BMW 530i, but my interior rattles not loud but enuff to irritate me! the center speaker dash cover rattles, the doors rattle a bit, and the rear deck! couldn't lexus do better with the quality design! What do you guys use to stop your rattles?
Old 03-08-12, 09:01 AM
brociouz
Uber 1337 Moderator
brociouz's Avatar
Get the dash rattle TSIB done.
Old 03-08-12, 09:15 AM
rookieIS
rookieIS's Avatar
i dont think he could unless he has an extended warranty
Old 03-08-12, 09:30 AM
brociouz
Uber 1337 Moderator
brociouz's Avatar
Ah, this is true. I guess I just assumed he had a CPO warranty.
OP, if you don't have a warranty to get the TSIB done, the DIY isn't so bad. It basically involves putting some foam padding in the areas where it rubs.
Old 03-08-12, 09:51 AM
mixa86
mixa86's Avatar
i have a 3rd party warranty
what is TSIB
Old 03-08-12, 10:18 AM
m4gicm4tt
m4gicm4tt's Avatar
Default Solving the rattles
I have, for the last week, been on a mission to solve all the rattles in my is350. I will post up some pics later so people can easily replicate what I have done. So far I have been successful but there is still more work to be done. I would love to have a thread full of pictures dedicated to solving all rattles people have experienced. I will share what I was able to find and maybe others will chime in and help too.
Really the first problem is knowing what rattle you have.
Dash: This is covered by many threads and is a LSB but since I dont suffer from it i have not payed much attention. There is a rattle that comes from steering wheel area and will get some pics of how to fix that. Here is a post for what I did to eliminate my instrument cluster rattle. https://www.clublexus.com/forums/6664323-post76.html
Glovebox: There are three potential sources of rattle, the latch, the back wall and the shelf. Isolate the cause by opening the box door, removing the shelf and securing the back wall of the box. (hard to explain without pics). I have not solved the latch rattle. It is a very quiet rattle and only happends when the door is up, I need to start felting things to see what solves it.
Doors/B-Pillar:I think there are only two rattles involved here. The first is actually the seat belt adjuster and the second is the door seal. Once again you need to trace the rattle to its origin to solve it. Hold all the pieces of the seat-belt adjuster and see if there is still a noise. The door seal noise may only happen when the window is fully up or there is no pressure on the door latch. Try pushing on the door and lowering the window a crack to see if you have found the genesis of the rattle. There are two was to solve tape the metal c shape on the door frame so there is a tighter seal of the door(other people have taken it to Lexus and get the frame adjusted but it closes funny) or go get 3M (wet type) Silicone spray and lube up your door seals and window seals. I did this and this stuff is flat out magic in a can! BUY THIS NOW!!!
Back windowI know there is a rattle here but once again I do not have it so I have not fully investigated it, I think there might be an LSB for this?.
Seat Squeak There is an LSB for this IF the squeak is from the bottom of the seat. You have to take the seat out and saw off two pins. (Circled in red below) I am trying to solve a creaky seat. Basically my side bolster has a creak and I need to get in there to fix.. I am still not sure as to how to take the back off my seat to fix this... any idea?????
Soon I will compile pictures and a method to eliminate these squeaks and rattles for good.
Last edited by m4gicm4tt; 03-08-12 at 10:23 AM. Reason: added a link to cluster rattle
Old 03-08-12, 10:32 AM
calvin2376
calvin2376's Avatar
what is TSIB
TSIB is a technical service bulletin, basically a document Lexus creates on common problems with their cars that they send to dealers that outline symptoms, warranty coverage info, and how to fix it.
None of the rattling issues will be covered by any Lexus warranty other than the factory 4 yr/50k bumper-to-bumper warranty, not even CPO. That's because all extended warranties (CPO and VSA) specifically exclude body and trim pieces. I also have never seen a third party/aftermarket extended warranty that covers body or trim pieces either. So these rattle fixes will be DIY or out of pocket.
Old 03-08-12, 10:55 AM
fewslowcar
fewslowcar's Avatar
I just got my LSB for dash rattle done yesterday. No more rattles. The funny part is the loaner IS250 they gave me had the same exact rattle. I guess this is a really common issue. Lexus should just do a recall for it, I understand it is not a safety issue however it is common enough that it might scare customers away.
Old 03-08-12, 11:12 AM
mixa86
mixa86's Avatar
I guess this is something japanese engineering will always have over german engineering..... the damn plastic rattles!!
Old 03-08-12, 11:27 AM
Hoac
Hoac's Avatar
my '11 IS rattles non stop everywhere. Moon roof when tilted, center console, passenger side dash, driver side pillar where the seat belt goes in...
My solution as of thus far... F sport exhaust + PPE headers + sub in the trunk... all of a sudden i can't gear the rattling anymore!
Old 03-08-12, 11:35 AM
embolism
embolism's Avatar
I shoved a black gum eraser cut into a wedge about an inch long into the space between my dash and the windshield right in the center where the center speaker grill is (even though there is nothing in there unless you have Mark Levinson). No more rattles!
Old 03-08-12, 12:43 PM
KillaIS250
KillaIS250's Avatar
A TSIB will be as far as it goes, at least it gives everyone 4 years/50k miles to have the issue corrected. It seems most people seem to experience the rattles before than anyways.
Old 03-08-12, 01:01 PM
tedward88
tedward88's Avatar
This may come in handy, especially for people who are out of warranty.. http://www.lexustsb.com/categories/Lexus+IS/
Sexus99
01-27-15 07:30 PM
Alex350
11-09-12 09:52 AM
bigblack06
04-26-11 05:59 PM
2IS350DT
01-28-11 01:10 PM
Shaft350
02-18-08 04:49 PM
Quick Reply: grrr the rattle!!
