emblem removal
emblem removal
I have a 08 IS250 and was wondering if the lexus and IS250 has studs in the back because i wanted to clean the trunk up but some1 told me it does have studs. Is this true or not or is there a certain year they stopped doing that. Plz help thanx for your input
If you don't want to go to the bodyshop, here's a couple of ideas in this thread
https://www.clublexus.com/forums/is-...ing-holes.html
I sprayed goo gone on the emblems and let it sit for a few minutes. I used an emblem removal tool that was provided with my black pearl emblems. It's just a plastic scrapper so it doesn't damage the paint. After you take off the emblems, there will be leftover double sided tape, you can use your nails or a towel and just wipe it off until its all gone.
you can also use guitar string i use that and it cut threw the double side tape like butter .then soak the area with goo gone leave is one for 10min or so and rub it off then when ever thing is almost done i finish it with a claybar(youll start there and may have to do the whole car after) and bam like new ...
