Tsib eg016-07
Tsib eg016-07
Anyone heard of this tsib eg016-07?... Lexus is performing the work for me under warranty. They will have my car 2-3 days and have given me a loaner. What exactly are they doing?
Search is your friend
AC003-07 DEC 07 A/C - Water on Front/Rear Carpets
PG008-07 NOV 07 Vehicle - Replacement Certification Label Information
PG007-07 NOV 07 Vehicle - Replacement VIN Plate Information
SS006-07 AUG 07 Electrical - Absorbed Glass Mat (AGM Battery Information
SS005-07 AUG 07 Restraints - SRS Component Disposal
EG016-07 JUL 07 Engine - Brief Rattle/Knock On Cold Start Up
TC008-07 JUN 07 A/T - 'World Standard' Fluid Information
EG015-07 JUN 07 Engine Controls - Bank 1/Bank 2 O2 Sensor Identification
AC001-07 JUN 07 A/C - Cabin Filter Replacement Procedure
NV007-07 JUN 07 Interior - Inside Mirror Vibrates
BO006R-06 MAY 07 Body - Rear Power Sunshade Won't Open Fully
EG008-07 MAR 07 Engine Controls - MIL ON/DTC P0172/P0175 Set
EG007-07 MAR 07 Engine Controls - MIL ON/Multiple DTC's Set
ST004R-01 MAR 07 Steering - Vehicle Pulling, Manual Supplement
PG001-07 MAR 07 Tire Monitor System - Diagnostic Tips
EG003-07 MAR 07 Cooling System - Leaks From Water Outlet Assembly
EL001R-06 MAR 07 Smart Key(R) - Repair Manual Supplement
TC002-07 MAR 07 Drivetrain - Driveshaft Replacement Precautions
SS002-07 MAR 07 Engine Controls - Techstream(R) ECU Flash Reprogramming
EG001-07 FEB 07 Engine - Timing Cover/Camshaft Housing OIl Leaks
TC009R-06 FEB 07 A/T - Identification/Serial Number Locations
EL002-07 FEB 07 Air Bag System - Repair Manual Supplement
EL016-06 DEC 06 Starting System - Vehicle Start After Battery Depletion
EL015-06 DEC 06 'Smart Key' (R) - Specifications
NV005-06 DEC 06 Body - Upper/Lower Windshield Ticking Noise
PG001R-06 NOV 06 Battery Maintenance for In-Stock Vehicles
SU001-06 OCT 06 Suspension - Shock Absorber Replacement Criteria
TC010-06 OCT 06 A/T - Reman A/T Serial Number Location
NV004-06 SEP 06 Interior - Rattle From Instrument Panel
EG014-06 JUN 06 Emissions - MIL ON/DTC's P043E/P043F/P2401/P2402/P2419
AC002-06 JUN 06 A/C - Intermittent Odors
AU001R-05 JUN 06 Audio System - Dash Speaker Connector Rattles
NV001-06 MAY 06 Interior - Front Seat Squeaking Noise
EG011-06 MAY 06 Exhaust System - Excessive Sulfur Odors
AX001-06 MAY 06 Audio System - SIRIUS(R) Radio Antenna Separation
AU001-06 APR 06 Audio System - Quick Reference Troubleshooting Guide
EG006-06 MAR 06 Engine Lubrication - ILSAC GF-4 Oil Recommendation
BO002R-06 MAR 06 Body/Lighting - Headlamp Support Bracket Installation
PD023-06 MAR 06 Parking Assist System - Initialization Procedure
EG001R-06 JAN 06 Engine - ILSAC GF-4 Engine Oil Standard
BO001-06 JAN 06 Body - Trunk Will Not Close
SS003-05 NOV 05 Audio System - CD Player Skip Verification
EG020-05 NOV 05 Engine Controls - MIL ON/DTC's P0171/P0174/P02195/P02197
BO012-05 NOV 05 Interior/SRS - Seat Cover Replacement Recommendations
BO010-05 OCT 05 Restraints - Seat Belt Extenders Available
CRIB150 OCT 05 Paint - Paint Codes
BO008-05 SEP 05 Body - Left Rear Door Lock Difficult to Operate
NV002-05 SEP 05 Body - Creaking Noise from Back Glass Area
SS005R-01 AUG 05 Antitheft - Diagnostic Tester Immobilizer Function
BO007-05 AUG 05 Interior - Glove Box Doesn't Open
BO006-05 AUG 05 Interior/Lighting - Dome Lamp Comes Loose
TC003-05 AUG 05 A/T - A760H Solenoid Identification
PG007-05 AUG 05 Tire Pressure Monitor - Sensor Registration/Initializing
PG005-05 JUL 05 Tire Monitor System - Tire Dismounting Procedures
BO004-05 JUL 05 Wipers/Washers - Wiper Blade Cleaning/Maintenance
EG012R-04 JUN 05 Engine Controls - Entering VIN After PCM Replacement
SU001-05 JUN 05 Suspension - Creaking Noise From Front Suspension
EL006-05 MAY 05 Electrical - Vehicle Start After Battery Depletion
BO003-05 APR 05 Restraints - Seat Belt Extender Availability
PD008-05 FEB 05 Tire Pressure Monitor - Sensor Activation
PD007-05 JAN 05 Body - Power Window Initialization Procedure
PD003-05 JAN 05 Body - Sliding Roof Initialization Procedure
PD004-05 JAN 05 Interior - Driver's Head Restraint Initialization
PD001-05 JAN 05 Instruments - Compass Calibration Procedure
Super Moderator
Super Moderator
TIS ( http://techinfo.lexus.com ) is the best place to get a complete list. Alldata ( http://www.alldatadiy.com/ ) should also be reasonably current. Neither source is free, but I believe you can at least view a list of TSIBs (but not the contents of them) on Alldata without subscribing.
