question about floor jack
Old 10-09-10, 03:38 PM
evogt500
evogt500's Avatar
Default question about floor jack
Today i finished changing the oil and filter of my is250. It was a pain in the a$$ because i had to use the cars jack ( the one that in the trunk of the car) to lift the car high enough so i can slide my "low profile" floor jack under the car. The floor jack wasnt long enough to reach the jacking point of the car which is located in front of the oil pan. My question is, is there a better method of doing this? All the other cars i worked on has the jacking point under the radiator or around there. Thanks for your reply.
Old 10-09-10, 06:56 PM
Eurosport
Eurosport's Avatar
go to walmart, buy 2 rhino ramps.
then you can just drive up on them no need for jack.
if you ever do need to jack it further, you'd just drive up on the ramps, then use your floor jack on the lifting point before the pan.
i never trusted the car's jack for more than quick wheel change if absolutely had nothing else to use...
Old 10-10-10, 02:42 AM
Jetfire
Royale with cheese
Jetfire's Avatar
ramps. you can build your own if you want.
Old 10-10-10, 02:49 AM
ApokC
ApokC's Avatar
Here's what I use...
You build a cheap lil wood ramp
Get 2 pieces of wood that are a foot long
Get 2 pieces that are 2 feet long
Get 2 pieces that are 3 feet
Nail them down on top of each other so that it gradually builds up like a staircase
Super easy to drive up on... and if your car is lowered, I guess you can try a 4th piece of wood
When your on the top piece, use a floor jack
Old 10-10-10, 12:06 PM
evogt500
evogt500's Avatar
Thanks for the replies and good ideas. I do have a ramp but it is meant for trucks and raises the car almost 2 feet in the air. I might try the wood method as i have some laying around. How thick was the wood?
Old 10-10-10, 12:44 PM
kuuqi
kuuqi's Avatar
rhino ramps are the way to go. i would not trust that whimpy jack to hold our cars up. i'd be scared of it collapsing and killing me in the process.
Old 10-10-10, 04:39 PM
ApokC
ApokC's Avatar
Well this is a DIY Rhino Wood Ramp haha
Official measure... 2 by 6
2nd level allows me to get a jack under the car
Old 10-10-10, 05:17 PM
evogt500
evogt500's Avatar
Thats sweet. I am going to make one. Thanks for the help.
Old 10-10-10, 07:02 PM
m3nv
m3nv's Avatar
You can find floorjacks for lower cars. This is what I own.
http://www.amazon.com/Profile-Garage.../dp/B0034WGWR6
Old 10-10-10, 07:15 PM
evogt500
evogt500's Avatar
My floor jack is also low profile. The problem wasnt that it couldnt fit under the car, but that once it is under i dont have enough room to actually push/pull the lever to jack it up since the jackingpoit is so deep.
Old 10-10-10, 10:11 PM
ApokC
ApokC's Avatar
I use the same type of floor jack.
Idunno what jack point ure referring to, but i just jack it up by the frame, that bar right in the middle of the tires.
works fine everytime, no weird noises or scrapes
Old 10-11-10, 01:23 AM
Jetfire
Royale with cheese
Jetfire's Avatar
http://www.mustangworld.com/ourpics/...amps/index.htm
Old 10-11-10, 03:34 AM
ApokC
ApokC's Avatar
^^^ ya whatever haha
lexman52
06-22-20 02:21 PM
tekjunke
RC F (2015-present)
04-24-19 05:32 PM
computerwi
RX - 4th Gen (2016-2022)
10-30-17 02:40 PM
DJKIBBLES
03-23-10 02:22 PM
grindin8o8
SC- 1st Gen (1992-2000)
09-11-09 05:36 PM
Quick Reply: question about floor jack
