Keyless entry question
Old 06-24-10, 06:51 PM
MBTC
MBTC's Avatar
Default Keyless entry question
On my previous car, I once left my keys in my jeans as they went through the wash which killed my keyfob.
Since there's no manual way to get into the car on a deadfob, what do you do if something happens like the battery in it dies?
Old 06-24-10, 07:09 PM
Gator Alum
Gator Alum's Avatar
hmmm I ran mine through the wash and it was fine. There is a rubber seal around the chip on the inside of my fob to keep it dry.
If you're batter dies, you put the cover off your door handle to reveal the keyhole.
To start your car, simply hold the keyfob directly against the start button and you'll be all set.
Old 06-24-10, 07:12 PM
MBTC
MBTC's Avatar
This can be done without tools?
Old 06-24-10, 07:18 PM
kickin8
2IS/2RX/4RX
kickin8's Avatar
you can use the mechanical key to open the door, then tap the key with the start button to start the car
Old 06-24-10, 07:21 PM
MBTC
MBTC's Avatar
How does the cover come off to reveal the mechanical keyhole?
If some of my questions are retarded its because I don't actually have my car until next week. I guess the dealer will go over this stuff but I like learning in advance.
Old 06-24-10, 07:43 PM
SPNinjA
SPNinjA's Avatar
There is a key slot underneath your door handle. Take the mechanical key, stick it in and pop off the cover. Then you will see the actual keyhole to open the door.
Old 06-24-10, 08:03 PM
MBTC
MBTC's Avatar
A-ha.. making sense now. Thanks.
supaIS350
supaIS350's Avatar
Here ya go...
Old 06-24-10, 08:47 PM
MBTC
MBTC's Avatar
Originally Posted by supaIS350
Here ya go...
Perfect! Thanks.
Old 06-25-10, 12:46 AM
Mv350
Mv350's Avatar
dont worry, i wondered the same thing for the first 2 weeks i had the car and some one at a my local meets showed me it came in handy when my fob battery completely died.
Old 06-25-10, 05:01 AM
tex2670
tex2670's Avatar
You can also keep a spare battery in the tool kit in the trunk, open the trunk with the mechanical key, replace the battery, and go.
Old 06-25-10, 09:48 AM
MBTC
MBTC's Avatar
Keeping a battery in the trunk isn't a bad idea, but wouldnt the temperature changes of being parked outside mean it's probably not going to work in a couple of years of being in the trunk? I have not had good luck with other batteries left in my trunk for long periods of time that are subject to hot/cold weather cycles.
Another thing, when I left my Nissan keyfob in my pants through the wash, I tried replacing the battery and it wasn't enough.. the water borked the entire keyfob.
Old 06-25-10, 11:30 AM
Initial_K
Initial_K's Avatar
Leave it in the glove compartment and it should be fine.
I had a friend who had the car for 3 years and she didn't know there was a key within the fob until I show her. lol
EJC
06-27-16 09:58 PM
NickTomsyc
04-03-11 09:29 PM
test_accou
05-12-10 05:35 PM
lx470man
IS F (2008-2014)
03-26-09 04:32 PM
mcfly
01-20-06 05:38 PM
Quick Reply: Keyless entry question
