most likely you can get them to sync. But you will only get 1 speaker to output sound, as the bluetooth handsfree use's your low end driver side speaker for sound output.
Why do you say that? I'd be surprised if they sync; an mp3 player is likely to use the BT headset profile, while the Lexus IS supports the BT handsfree profile.
You need the A2DP profile to support bluetooth streaming.
+1 and the Lexus doesn't support the A2DP profile. I don't believe any OEM HU's support the A2DP profile, but there are a few aftermarket HU's that do (Sony, Alpine, Kenwood, etc).
Hopefully that will change as Ford may be setting the bar a little higher this fall.
