Engine Oil Quantity?
I just changed my engine oil and filter this weekend. I only put in 6qt and oil level is staying in between the marks. I driven it about 4 times and checked the level, and level is still the same. Is this normal? I read somewhere that it will take about 6.8qt, remind you that I had the front of the car on rhino ramps.
Super Moderator
I also use Rhino ramps, but I perform the change on a slightly downward sloping section of asphalt such that the car is level when it's on the ramps.
Car took just over 6.5 quarts to bring it to the "full" mark.
It's 6.7 qts for a standard oil/filter change (although anyone who happens to jack up the side of the car opposite the drain plug to really empty the pan will notice that it takes nearly 7 qts to get back up to the high mark on the dipstick).
Tech Info Resource
One of the cheap tricks on sprint racing bikes is to run the oil just above the low mark when hot. It reduces crank windage. If I intended to dyno my car, I would definitely run the oil intentionally at the low mark if I wanted best numbers.
haha. oh man i seriously hope you're joking
Tech Info Resource
No, I'm not. It works. It's just one of the things Toyota got busted for doing with their dyno numbers before the requirement to use the SAE standard.
I'm starting to think that dealers have the least qualified person to do the oil changes, since the techs might be busy with something more important.
