Need advice
Need advice
I'm looking into getting BRian Crower stage 2 cams. Should I change my valves springs and retainer or can I leave the head stock and just change the cams.
HKS Cam Gear
http://intensepower.com/hkscamgearsu.html
There are a lot of ways to tune your car from the basic to the stand a lone. Not sure what your goals are with you car. For the basic you can tune it with an Apex'i AFC (lots of different versions) or an AEM EMS.
The 2JZxxx is a great engine and tolerate a lot, but make your AFR and everything is tuned right, so that you can enjoy the engine.
HKS Cam Gear
I want a little more power as of right now until I can boost the motor.
Upgrading cams will require a few other components to also get upgraded. Cams will demand more oxygen and fuel, so be sure to have a clean intake and injectors. It also wouldn't hurt to change ur spark plugs if you haven't already done it.
