IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Is-300 trac off problem help!!!!
Old 10-24-12, 05:37 PM
nickkm
nickkm's Avatar
my trac light flashes every few seconds. what could it be?
Old 10-24-12, 11:46 PM
L3xu5Junky
L3xu5Junky's Avatar
Could be an emissions leak. At least that's what my problem was when I had the same CE light and "blinking trac off" light. Like I said before I would check those two parts first, and if you have a diagnostic tool handy, or know somebody that does, we could help you out much more if we knew the error code. They're both pretty easy to overlook, but very likely could be your problem. When you check them though, pay attention to the stem inside the fuel vapor feed pipe that likely has broken off inside the actual housing or hose; and for the ventilation hose look in about the mid section with a flashlight and make sure the restrictor (basically a small washer) isn't messed up or missing. It's almost guaranteed that the hoses for both need to be replaced since they're probably old, dry, and possibly cracked through. I would again recommend replacing them with factory parts. Let me know what you find and I'd be more than happy to help if I can.
Old 10-29-12, 05:10 AM
jmedina23
jmedina23's Avatar
Thanks for the info.
Old 11-13-15, 11:54 AM
ps300is
ps300is's Avatar
Default track light, engine light.
OK same thing here, made hard turn onto the onramp hwy. The lights came on trak flashing. Must have something to do with hitting turns too hard and fast.
Originally Posted by AAHawaii07
Hello,
Drove my IS-300 today I made a hard left turn (trying to beat the yellow light). Latter I noticed that my check-engine light was on and the TRAC OFF ICON on my dashboard keeps flashing every 3 seconds. After I parked my IS300, turned off the car and turned in back on and still the same problem shows. "Solid check-engine light and my TRAC OFF keeps Flashing every 3 sec". Anybody has encountered this problem before?. Please feel free to post here.
FYI:
- My vehicle is a 2002 Lexus is300 approx: 85,200miles. 5sp. mods, recently added fully adjustable coilovers.
is2003
05-16-17 08:31 AM
TXKSHunter
09-10-13 04:27 AM
eep4life
06-14-12 12:25 AM
Rominu7
01-06-10 11:46 AM
dragion
07-25-01 08:52 PM
Quick Reply: Is-300 trac off problem help!!!!
