Newbie after some tech advise
Hi
I have been reading you BBS for a while and find you all a very nice bunch and wonder if you guys could help me out. Ive Owned a couple of toyotas and i am after a IS 300 now to play with. questions are:
Will a 2JZ GTE bottom end mate up to a GE head?
If not is it possible to swap the internals from the GTE to The GE block.
Or is it easier just to do a total transplant.
Many thanks
Many thanks
Re: Newbie after some tech advise
Originally posted by migster
Hi
Many thanks
Hi
Many thanks
I had the same dillema as a matter of fact......while I am going thru the process of a en engine build and turbo install....
here is a picture of my 2JZ-GTE bottom along with the stock GE head:
Wow very nice project!
I am gonna bore you rigid now if you don't mind,
We have a built 2JZ-GTE bottom end, what modifications will be needed on the engine mounts?
What is the compression ratio when mating a GTE short block to a GE head
What head gasket is prefered
and........... Is it worth it? or should we leave the GE short block and fit a 3mm GReddy head gasket. Ideally we want approx 500 rwhp, probably using a T61GT35, so is there any point? This will be a daily driver.
Lastly, we get a 5 speed autobox here, will it cope with mods?
TIA
TIA
TIA
TIA
very intrriguing questions which I honestly do not have the personal experiance or expertise....all my info is hearsay.... I will try to answer you're questions though... I do believe by using a NEW 1998 GTE block, it can utilize the engine mounts with NO modifications.....the compression ratio along with a stock GTE headgasket, would be 8:5:1 as far as I know...
I suggest E-mailing and contacting here: Jeff Stevens Jeff@turboeast.com
www.turboeast.com
he will be able to answer you're questions in great detail...good guy and good products for the IS300.....
good luck, and keep me posted on you're progress...
