Stock exhaust diameter? DIY muffler delete pending
Old 01-14-15, 05:49 PM
LexusNN
LexusNN's Avatar
I have a muffler delete for sale so you can save your stock setup!!
Local pickup only though...
Old 01-14-15, 07:08 PM
Spooled
Spooled's Avatar
I'm removed the mufflers and drove the car and both my wife and I love the how it sounds. But as you can see the last exhaust hanger before the Y before the mufflers. Your existing piping will flop and hit the underside of the vehicle. I just want to cut the pipe just past the hanger (where the red arrow is pointing in original post) that way it will be the largest diameter possible and supporting the rest of the exhaust going towards the engine.(muffler delete, cut the piping at the hanger)
Old 01-15-15, 04:57 AM
juanmedina
juanmedina's Avatar
Are you going to delete your secondary cats as well?
I went to mufler shop to get my exhaust modified and they say that cannot remove the secondary cats for me. They said that they will charge me 100 bucks for cutting my mufflers and welding a straight pipe.
I am thinking that for that money I can buy a harbor freight flux welded and do it myself; removing the cats and mufflers. What piping are you going to buy? Stainless or mild steel? What size?
Thanks
Old 01-16-15, 05:17 PM
Spooled
Spooled's Avatar
I want to essentially have what you see in the picture (just imagine a vband right after the flange (on the muffler side) cut the factory muffler section and have a vband flange installed with a turn down. I was considering having a vband flange installed right where red arrow is pointing in the original post. Vband the muffler section and have a spare vbanded 45• turndown. That way I can run an optional turn down piping muffler-delete, or run stock mufflers. Like a plug n play muffler delete, that utilizes the factory exhaust hanger.
Attached Thumbnails Stock exhaust diameter? DIY muffler delete pending-image.jpg
Old 01-16-15, 05:44 PM
PPEHeaders
Sponsor
PPEHeaders's Avatar
Originally Posted by Spooled
I was asking about the diameter of the pipe at the exact location in which the arrow is pointing. I was planning on cutting the muffler section, right at the area indicated in the original post, and welding a turndown so the exhaust isn't pointing directly towards to read diff.
I do not care to know the size of the stock muffler tips lol
If you need welding work done, or U Bends, or other fab parts, we are in Tempe.
Old 01-16-15, 06:12 PM
F_Throttle
F_Throttle's Avatar
Does anyone have a part number for a flange, that would replace the axleback?
Old 01-16-15, 10:53 PM
Levitics
Levitics's Avatar
I did my dual exhaust last week. It sounds deep and loud. Just a little raspy at times when i step on it hard....lol. if you want to check out how it sounds. Check my instagram @_lexus_isf
I did it dual. The cut started from 2nd cats, two pipes of 2.5 diameter all the way back. And i didnt fo any Hpipe or Xpipe, is all double single piped. No resonator and No mufflers. I just added the tips to make it look more like a real exhaust. And i know it may look about an inch too much sticking out, but i will fix that...lol. and with this set up i dont get drone inside. I can have a great conversation inside the car with them closed.
Attached Thumbnails Stock exhaust diameter? DIY muffler delete pending-20150115_171618.jpg   Stock exhaust diameter? DIY muffler delete pending-20150115_171152.jpg   Stock exhaust diameter? DIY muffler delete pending-20150109_153748.jpg
Old 03-15-17, 06:32 PM
FFM
FFM's Avatar
Well I jumped the gun and ordered 2.5" inlet dual tips and then decided to actually check the piping diameter after the Y split and it's like 2.125" or some garbage like that lol. Guess I order some 2.5" pipe, slip over and weld the gap? Figures.
Old 11-24-20, 07:25 PM
Thebmx21
Thebmx21's Avatar
for the part of the pipe where the red arrow is pointing, does anybody know what the inside and outside diameters of that pipe are? i want to make sure i get the right size pipe when i get my axle back kit and one of the websites i was on was giving me all sorts of different sizes for the pipe
06GFM
10-28-17 03:47 PM
Sthall21
05-05-17 02:26 PM
Kozy
04-02-15 03:33 PM
GRN MNSTR
Performance & Maintenance
08-28-09 07:34 PM
Quick Reply: Stock exhaust diameter? DIY muffler delete pending
