Need help passing safety inspection for registration
Old Nov 24, 2020 | 04:56 PM
Josh331's Avatar
Josh331
Post Need help passing safety inspection for registration
Hello!
Just got my safety inspection done for a 2008 Lexus ISF in my province (Saskatchewan, Canada) and it needs some work. Just a couple questions...
(1) The car came with VLAND aftermarket headlights (the one that looks more like the current Lexus headlight style) and according to the garage that did the inspection, the front end of my car must have parking lights that are amber. Now my question to you guys/girls, can the VLAND headlights show amber color lights when the car is parked? And if so how do I go about doing that? If not, do our OEM headlights even display some sort of amber on the headlights? I would prefer to find some way to make the VLAND display amber, as I do not wanna buy the OEM only to sell them...
(2) The car was previously lowered to the point where it rubbed and it destroyed the front driver inner fender liner and I would need to buy a new one, my question is, can I buy a front driver inner fender liner for a non ISF Lexus or do I have to buy one specifically for a 2008 Lexus ISF?
(3) For some reason, both my rear brake rotors are no longer good and would need replacing, my question is; currently it looks like I am running the OEM brembo rotors, do I also have to run the OEM brembo rotors or can I upgrade to something like a stoptech rotor in the rear and still run the brembos up front? Also I have seen a huge price difference on the OEM brembo rotors here in Canda, what do they usually go for new?
That is all the questions I have for now...
Thank you for your time, and I hope to hear from you guys/girls.
Old Nov 24, 2020 | 05:09 PM
Joe Z's Avatar
Joe Z
What Country is your Safety Inspection for ??
Thanks
Joe Z
Old Nov 24, 2020 | 05:44 PM
flowrider's Avatar
flowrider
Veteran: Air Force
^^^^SK = Saskatchewan = Canada.
To the OP - I don't know if the VLand headlights can be changed - Maybe some else can chime in.
2. I believe the fender liner from a second generation IS of any model will work just fine.
3. Any third party rotor specifically labeled for the ISF should work fine. As an aside, the rear rotors from an RCF or GSF will fit an ISF. I hade third party sllotted rotors on my ISF.
And welcome to the forum, lots of GREAT information here and lots of GREAT folks to share it with.
Lou
Old Nov 24, 2020 | 05:46 PM
Josh331's Avatar
Josh331
Thanks
Joe Z
I am located in Saskatchewan, Canada. Each province has their own safety inspection iirc.
Old Nov 24, 2020 | 06:43 PM
KenISF's Avatar
KenISF
Vland do not come with parking lights. You would need to drill into and wire up lights if you wanted them.
Old Nov 25, 2020 | 05:02 PM
Josh331's Avatar
Josh331
Lou
Awesome, thank you for the reply. There was lots of good information.
Old Nov 25, 2020 | 05:03 PM
Josh331's Avatar
Josh331
Damn, I'm little bit scared to drill into it and wire it up. I will probably end up going OEM or finding an aftermarket option that has parking lights that is cheaper than OEM. Thank you for your reply!
Mitleider
Nov 30, 2020 07:18 AM
mindcrime
Mar 31, 2017 06:43 PM
2URGSE
IS F (2008-2014)
Mar 24, 2016 03:26 AM
melbitoast
Mar 29, 2012 05:46 PM
timoc42
Apr 4, 2004 03:19 PM
