Warranty/Extended Warranty Up Soon...What to look for?
Old 09-15-14, 01:14 PM
MisterSkiz
MisterSkiz's Avatar
Default Warranty/Extended Warranty Up Soon...What to look for?
With the warranty up on my car (08 IS-F with 48k) end of next month, I'm going to have the car taken in for its last at dealer oil change and have them go throughout the whole car.
I'm thinking of having them look at:
1) shocks
2) tie rods / end rods (front and rear)
3) no leak from transmission
4) no leak from radiator
5) boots on steering rack
6) boots on the rear axles
7) rotten/worn or leaking bushings
8) Heated seat functionality
I know my tensioner is making some noise..will have them replace that.
I am worried about the LED bars going on in the dash, and the Nav unit not displaying or responding to inputs...but they are not showing any symptoms and I intentionally turned down the interior lights when I got the car to avoid them burning out...I figure if they go I can pretty much goodwill the repair.
I already had the rear sub replaced and only keep the bass at +1
Anything else you guys think I'm missing?
Old 09-15-14, 01:25 PM
I8ABMR
I8ABMR's Avatar
check your water pump too.
Old 09-15-14, 09:20 PM
speeddem0n
speeddem0n's Avatar
^ yep, beat me to it. Im having Lexus replace mine possibly this week.
Old 09-16-14, 04:04 PM
MisterSkiz
MisterSkiz's Avatar
Yup, got my water pump done already!
Old 10-17-14, 05:54 PM
MisterSkiz
MisterSkiz's Avatar
Had car looked through today....I swear the tensioner or some pulley has its bearings roaring...but you can only hear it from in the car after driving...from the outside its quiet...hmm
They caught that the rear passenger axle appeared to be weeping fluid...gonna be getting a whole new axle under warranty.
Old 10-17-14, 07:07 PM
dannyk8232
dannyk8232's Avatar
Does it happen mostly in 1st and 2nd gears as the revs get above 3k or so? Sounds like a supercharger winding up?
Old 10-18-14, 03:20 PM
MisterSkiz
MisterSkiz's Avatar
Nope. I dont have anything like that sound.
My sound sounds like something rumbling (bearings) when the car is in park after driving.
Old 10-20-14, 11:31 PM
ghd8989
ghd8989's Avatar
Are they known to go bad early?
Old 10-21-14, 06:13 AM
kzlflash
kzlflash's Avatar
Is the water pump issue only with the 08s? Or does it affect the 11s also?
Old 10-21-14, 07:21 AM
VtotheJ
VtotheJ's Avatar
^Most 08's had the faulty water pump, they were changed in the later years.
Old 10-23-14, 05:01 AM
MisterSkiz
MisterSkiz's Avatar
Got my car back....the axle was just seeping some grease.
The splines on each end of the axle were fine, not twisted. The tech (who is my buddy who helped me install the Torsen diff) said there was no sign of abuse at all on the axle he replaced. I told him flat out i'm hard on the car (as he was already aware).
In all I have had the following done under warranty since I bought the car with around 20k on it (at 48k now)
- HVAC assembly replace (someone? broke the fresh air/recirculate door when I had the car)
-Rear subwoofer replaced
-Water Pump and serpentine belt replaced
-Rear Passenger side axle replaced
arnieosp
10-23-15 05:36 PM
supafreeza
IS F (2008-2014)
12-17-14 11:12 PM
callmeshor
08-12-11 05:45 AM
bwallace2
GX - 1st Gen (2003-2009)
04-15-10 01:00 PM
mwbuck
RX - 1st Gen (1999-2003)
05-07-06 09:32 AM
Quick Reply: Warranty/Extended Warranty Up Soon...What to look for?
