HELP: Front fender VIN stickers?
Test drove an IS-F today and was checking if all the body panels were original. I could not locate the ones on the front fenders. Where do I find these? Is it under some trim? Could someone please attach a pic?
Also, how about the trunk lid? I didn't see it readily exposed?
Thank you
Thank you
VIN tags are visible in the following locations:
front fenders (roll back weatherstripping on each side near center of engine bay)
hood (center near leading edge)
front door (open door and look on edge)
rear door (open door and look on edge)
rear fenders (need to remove access panel in trunk)
pics of above locations
http://imgur.com/a/ay673
I don't think there is one on the trunk though.
- Kirk
Thanks for this, is there a less zoomed in pic of the rear fender VIN tag...just trying to see which access panel is removed to be able to see the VIN tag there. The pic is too localized so cant tell where to pull the cover to see the VIN. Thank you.
https://www.clublexus.com/forums/is-...ml#post8969480
I just had my trunk apart to replace rear struts and happened to take a pic of the vin tags, hopefully you can see the locations better
AutoSexy13
10-12-23 11:44 AM
Stealth2is
03-01-18 05:44 PM
hijack87
05-11-17 05:24 AM
