My rear tires are rubbing
I need you guy help, My rear tires are rubbing pretty bad. What do i need to fix the rubbing and set up are
19x10.5 +29 on 275/30
I found the camber link kit, Is this going to work?
http://www.iapdirect.com/06-13-lexus...s-f-67520.html
Thanks.
Thanks.
that's a pretty aggressive set up.. you will need a roll for sure, and even that I’m not sure if it will be good enough. Also your stance will play a big factor. The camber arm will help allot.. I believe Hyper ISF is running close to the same spec if not his is a little more aggressive and he's running camber arm just to fit it. GL
Received 1,064 Likes
See below...
I didn't waste my time with heating & rolling..
I shaved / grinded off the excess metal and used a few layers of oem touch up paint to seal it up..
Looks & feels like OEM
laxton
IS - 1st Gen (2001-2005)
02-08-13 02:40 AM
AtlantaVIP
12-30-11 05:05 AM
