TPMS Sensors from RCF won't register
Old 03-06-17, 05:35 AM
STLblueF
STLblueF's Avatar
Default TPMS Sensors from RCF won't register
Has anyone successfully registered TPMS sensors with a 08-13 ISF from a newer model RCF or GSF? It appears the Denso part number changed (was 5500103, now 5500105).
I have the 4 sensor IDs programmed via techstream but it appears the they cannot communicate (despite both being 315mhz). Looks like I will need to buy the older set of TPMS sensors and have the tires re-mounted & balanced to get the light to turn off...
Old 03-06-17, 06:13 AM
Joker4096
Joker4096's Avatar
Are they all showing 0 psi? Are they new?
Old 03-06-17, 06:42 AM
STLblueF
STLblueF's Avatar
They are not new. The tire shop's snap-on TPMS tool is able to read them, they all show the correct PSI and the battery checks good on all of them. However, techstream is showing them all at 0 psi, so it doesn't appear that the sensors can communicate with the 08-13 ISF's. Looks like 2014 ISFs use the same sensor as the 15 RCF, so maybe something changed at that time.
Old 03-06-17, 07:34 AM
Joker4096
Joker4096's Avatar
Hmmm weird, must be compatibility issues.
Old 03-06-17, 07:51 AM
redcrxsi
redcrxsi's Avatar
You might ask flowrider. Lou is running RCF wheels, although has custom tires so he may have just reused his existing tpms.
Old 03-06-17, 08:33 AM
flowrider
flowrider's Avatar
Received 1,831 Likes on 1,293 Posts
^^^^Here! And no, they won't work. My wheels have VDO sensors installed. The sensors from the RCF didn't communicate with my ISF.
Lou
The following 2 users liked this post by flowrider:
s2kjer (08-26-17), STLblueF (03-06-17)
Old 03-06-17, 08:54 AM
STLblueF
STLblueF's Avatar
Apparently the RCF uses pacific PMV-C010 sensors and the ISF uses PMV-107J sensors. At least now I understand why neither the tire shop's tool nor techstream could get them to work. I guess there is more to it than just being on the same frequency and registering the IDs.
Old 08-26-17, 02:05 PM
s2kjer
s2kjer's Avatar
I am in the same situation after putting GSF wheels on my ISF. Looks like I will be buying new sensors!
bswhitener
06-15-23 07:18 PM
RayKnight
GS F (2016-present)
05-11-17 05:31 AM
Scrutator
03-12-16 02:21 PM
mandyfig
02-20-11 06:12 AM
Quick Reply: TPMS Sensors from RCF won't register
