Trunk will not open without keyfob.
Old 01-12-17, 01:10 PM
JKStylez
JKStylez's Avatar
Default Trunk will not open without keyfob.
Hello CL,
I purchased a 2011 ISF about 3 weeks back and coming from driving a is350 from 2005 until now, i noticed something off about the trunk.
The 2011 ISF, if the car is unlocked and I went to push the button on the actual trunk (not trunk release from driver seat or remote), it will not open (without having the key on me). I make sure all doors are unlocked but it still doesnt respond. However, when i have my key on me, the trunk opens fine when i try to open it. Not sure if this makes sense but i wanted to ask if this was intentional or something that i should get looked at. I also have a 2014 CT and that car doesnt have an issue with opening the trunk without having the key on you either. Both the CT and IS350 behaved the same way (trunk opens even when you dont have the keyfob on you, as long as all doors are unlocked).
Any input is much appreciated!
-Andy
Old 01-12-17, 02:24 PM
PatrickISF
PatrickISF's Avatar
Its a proximity sensor, you have to have the key on you to open the trunk using that button. Otherwise you can use the button inside the car to open the trunk.
Old 01-12-17, 04:25 PM
chris07is
chris07is's Avatar
check the glove box compartment, theres a security button there...
Old 01-12-17, 05:22 PM
isfvss
isfvss's Avatar
Its normal.
Old 01-12-17, 06:37 PM
Joker4096
Joker4096's Avatar
I have never seen this.
Old 01-12-17, 07:25 PM
96300NAZ
96300NAZ's Avatar
Like mentioned. Glove box switch. Every now and again something bumps it.
Old 01-12-17, 07:59 PM
j3ff
j3ff's Avatar
^^ agreed. Supposedly it's to keep the valet boys from getting in? Assuming you lock your glove box.
Old 01-12-17, 10:44 PM
JKStylez
JKStylez's Avatar
Thank you for the feedback guys.
I would like to clarify a little.
My old cars would do this. I park in my garage and leave the car unlocked. I put my keyfob in the house and need to grab something from the trunk of my unlocked car. I would just go up to the trunk and press the button and it will open. This was the case with both my IS350 and CT200.
However, with the ISF, i will always need to have the keys on me to unlock the trunk via the button on the trunk. even if the car was originally unlocked. Do you guys get what im getting at?
Old 01-13-17, 04:46 PM
ISF4life
ISF4life's Avatar
lolz damn newbies :P
Old 01-14-17, 12:19 PM
flowrider
flowrider's Avatar
Received 1,831 Likes on 1,293 Posts
Post #2 is the only correct & helpful answer Glovebox switch is a red herring for the OP's question
Lou
Old 01-15-17, 08:44 PM
JKStylez
JKStylez's Avatar
So here is a question for you guys.
If you do not have your key on you but your car is completely unlocked, can you open your trunk from the button on the exterior on the trunk?
(I understand there is a proximity sensor, otherwise i would have the same problem with the driver DOOR....)
Old 01-15-17, 09:06 PM
Miqueaseli
Miqueaseli's Avatar
One thing to check for also . Make sure you have an ISF key fob met 2 owners that bought their F's and had an is250 or is350 key programmed to their F and they couldn't open put down their windows if they held open button . May seem dumb but check it out also.
Old 01-15-17, 11:26 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,849 Likes on 2,334 Posts
Switch? Key fob?
No. The IS F does not do what you are asking. You must have a key on your person within 1m of the trunk to open it with the switch on the trunk deck. It will not open with the car unlocked without the key. The wife's Scion would do this. The IS F does not do this. The GS F does as well.
Old 01-16-17, 10:22 AM
JKStylez
JKStylez's Avatar
^^^ Thank you! This is exactly what i was looking for. Just affirmation that there is a difference among Toyota/Lexus vehicles since both my previous lexus' did this.
This saves me a trip to the dealer to inquire. Thanks again lobuxracer.
PHASMA_3IS
03-19-19 07:10 PM
LexusWhy
12-05-17 03:37 PM
Lin1j2
ES - 5th Gen (2007-2012)
08-05-17 09:35 PM
sprtn131
08-13-15 05:48 PM
attimus02
ES - 6th Gen (2013-2018)
08-27-12 06:58 AM
Quick Reply: Trunk will not open without keyfob.
