OEM IS-F wheels: Are they Spacer Friendly for those who run H/R Integral spacers?
I know some OEM wheel companies have great thought in the design and have provisions for “Recessed” openings in the back of the wheel so we can use H/R Integral spacers that are LESS THAN 25mm by allowing the protruding studs to go into the recessed holes.
If you have no clue what I’m talking about then you probably have not done this before so I’m asking IS-F owners who have spacers, do you remember if there are recessed cutouts behind the OEM wheels? Or anyone have a picture of the backside of the OEM IS-F wheel?
I’m trying to buy some H/R Integral spacers around 15mm so that means the OEM studs will protrude past the spacer. I prefer NOT to change out the studs for longer studs which is why I’m asking…
Look at my example picture below. Notice the wheel on the left has the holes and the ones on the right do not!
In this picture the spacer is 25mm so the oem studs are covered by the spacer due to the 25mm thickness but I don’t think a 25mm spacer would fit on the OEM IS-F rims?
I put 15mm all around with eibach springs. No rubbing issues. I do put the ones changing the bolts and they come in the kit. This is how the offset has to come from factory. By the way mines are H&R
MISF (04-11-19)
gumbylude
IS F (2008-2014)
21
04-06-16 01:00 PM
D2M
Wheels and Tires Classifieds
02-18-13 04:44 AM
