Spacer 101
Old Apr 18, 2017 | 02:57 AM
ldc's Avatar
ldc
Default Spacer 101
Just wanted opinions on two options, I've been researching a lot on what's safe and what's not but I really wanted this wheel.
Circled red are the places that the oem studs protrudes out from the 15mm spacer surface and hit. It's a pity the indentation is so deep yet it is not centred.
So here are my options.
1) Trim the oem studs down flush with the spacer surface. This I have measured to be 1/2 the studs (I know what is massive). The low profile nut that comes with the spacers only need half the studs to secure the spacers to the hub.
(obviously if I put back my oem wheels I will get new oem studs put back in)
2) Replace the 15mm bolt on spacer with 5mm non-bolt on type and get longer extended studs.
I only need 5mm clearance.
Old Apr 18, 2017 | 03:13 AM
isfvss's Avatar
isfvss
Spacers are NOT recommended just ask your insurance company they are only good for looks. There are a lot of threads on this all the pros and cons, it all come up to you.
Old Apr 18, 2017 | 03:36 AM
ldc's Avatar
ldc
I didn't ask whether they are recommended or not and I know about legality etc. If I have a WRX or similar I would not even think about spacers but I sit in traffic to and from work, drive like a granny and don't know what tracking means. Also my reason is not becos I want an aggressive or hella flush look, it's to clear the suspension arm (only applying spacer for the fronts not rear).
Old Apr 18, 2017 | 12:41 PM
XSV's Avatar
XSV
Option 2 seems the safer route.
I've seen ppl cut studs as well, but then you run into damaged threads that won't thread a nut.
Old Apr 18, 2017 | 01:53 PM
ldc's Avatar
ldc
I've measured the amount of turns on a nut when putting in 5mm spacers and there's about 9 turns left and it's using oem lugs. I read that the safe amount is 6-7 turns. I think option2 is safer too given the only risk is the centre hub that the wheel sit on is reduced my 5mm.
Old Apr 18, 2017 | 06:34 PM
belac's Avatar
belac
I've ran 5mm slip-on spacers with OEM studs for about 4 months now without issue.
The lugs have plenty of turns and I don't feel that it is unsafe at all.
Also my car is driven pretty hard and through some pretty rough road conditions.
I don't recommend cutting the OEM studs at all (if you decide to run a bolt-on spacer). If you change wheels or want to return to stock you'll have to replace all the studs which is a PITA.
Old Apr 18, 2017 | 10:27 PM
ldc's Avatar
ldc
Yeh I agree it's too much hassles with option 1. I have to wait for 1 month to get my 5mm.
Old Apr 19, 2017 | 08:22 AM
primavera's Avatar
primavera
Have the machine shop or someone with the floor drill press bore out these pockets to accommodate the wheel studs. It's not that difficult, just measure how much your studs stick out past the spacer and how deep you need to bore out the pockets.
If in doubt contact these guys, they will do it in a heartbeat.
https://www.instagram.com/needpowdercoating/
Old Apr 19, 2017 | 06:23 PM
ldc's Avatar
ldc
Thanks I too have found a place that will widen the hole. There was another same brand, same type and size wheels that has the hole right to the edge as standard, not sure why this isn't so for this wheel.
Now I have three options, plus the 4th of not doing all 3 options and get another set of wheels.
Old Apr 19, 2017 | 08:08 PM
bazzle01's Avatar
bazzle01
Smile
I vote for the 4th option.
Old Apr 19, 2017 | 10:31 PM
ldc's Avatar
ldc
Can you give me 1k for me to go with option 4?
Old Jan 10, 2018 | 03:35 PM
Mufis's Avatar
Mufis
I agree I run 5mm spacers on the front of my is350 to clear the my big brakes with a +45offset rim in front
Old Jan 11, 2018 | 07:47 PM
markjustus's Avatar
markjustus
I had to do the same thing to get my wheels to fit, cutting down. The studs in the front. I got tired of running +9 in the fronts and just threw on new studs when i went back to stock
Old Jan 13, 2018 | 03:19 AM
Mufis's Avatar
Mufis
Here's some advice in this video from a driver not an insurance agent.
Old Jan 13, 2018 | 03:25 AM
Mufis's Avatar
Mufis
I know what you mean about clearing the suspension arm...
