2016 IS350 F-Sport Turn signal LEDS
Seems like there was some kind of change for 2016? Why do none of the big manufactures seem to list 2016 as compatible for LED turn signals, etc..??
http://store.ijdmtoy.com/Error-Free-...s-p/20-009.htm this one in particular.
I did order a set of 2015 Lexus "ghost" door projectors (puts the lexus logo on the ground when you open a door) and sure enough they didn't line up right
What do you mean with "they did not line up right"? I installed them on my 2015 and got a perfect Lexus logo. You can even rotate the insert to make it straight with the car.
These were the ones I ordered..and returned.
The projector could not be made to aim straight down and make a clear lexus logo...
Amazon.com: Wind Fire D006- Toyota/Lexus/Infiniti - No Drilling Changeable Courtesy Ghost Shadow Lights -Lifetime FREE logo chips replacement 2-pc set: Automotive
Got exactly the same, was crooked when installed but was able to move the mask holder to straighten it out, it actually came with a little tool for it. That's odd !
Did you face the issue where the signals flash faster than normal ? Usually this issue happens when you install a lower consumption bulb and the car thinks that the bulb is not working.
I did white in the front. I love the look of it when you hit the locks on the key fob. Matches nicely to the headlights/fog lights/DRL (non F sport with LED headlights). Only problem I have is my car has no front plate (required in NY, totally illegal window tints, and a few other not so police friendly modifications) so I do get paranoid when I use them, and find myself not signaling as much as I should just from fear of a cop seeing the flashing white (which are very bright) and pulling me over
Post meant for alvitdk
I used to have white led as well but changed it back to amber after a while.
