Stock Front Lip Unclipped
So I made a mistake an accidentally pulled too far forward and when I went to leave my front lip skid on the parking block. I got home to check it out and it looks like maybe one of the front lip clips are undone? Any ideas on how to fix this, I haven't pushed around too much in fear of breaking a clip. It's only unclipped in the little portion on the photo.
Lip is factory, not aftermarket.
Thanks!
Thanks!
Yeah, you've pulled it out far enough that a couple of tabs have pulled out (or broken). Much easier if you can get it up on a lift. There's a built-in clip (at the middle end), 2 plastic plugs (one at either end), one screw (on the outside end) and about 6 tabs along the length of the lip - a couple of these have pulled out. You'll probably have to take it off to set the tabs and then put in the plugs and the screw (in that order).
Edit: I just poked my head under it right now, looks straight forward and I was able to see the one clip that came out of its slot, not broken thankfully - thanks again for the advice!
Thanks for the help thus far!
Best,
George
